Author Topic: pre f/l electric window switch removal  (Read 1728 times)
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
« on: 27 March 2011, 20:29:22 »
The ongoing saga of my MV6 continues...
It's a '98 mini f/l, and has the pre-f/l centre window controls.
The front passenger window switch needs cleaning or replacing - it won't move the window up, except when I insert a thin blade screwdriver down one side of the switch case.
So...
Can one of the switches be replaced seperately, or both (front and back) together?
How do I unplug the switches?
Do the wires pull off the switches, or is there a plug under the brake/gearbox cowling?
Carpe Incendium
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: pre f/l electric window switch removal
« Reply #1 on: 27 March 2011, 22:07:15 »
if you have rear vents in the centre console-the centre console will have to come off the switch connecters are in there, you will also need to take gearstick surround off and then prise the switches out  :y
they can be replaced seperately  :y
if you try to prise them out without removing the surround they break  :(   i know  :-[
« Last Edit: 27 March 2011, 22:17:51 by fiend61 »
bigegg
  • Leeds
« Reply #2 on: 28 March 2011, 11:38:08 »
switches removed from surround easily enough, without any breakage.  :y
is there a guide for removing centre console?
Carpe Incendium
