Author Topic: noisey radio  (Read 1811 times)
jrchef
noisey radio
« on: 02 April 2011, 00:35:59 »
my 2.5 cdx 1997 omegas radio is picking up noise from the engin elecyrics how do I fix it  any help please as it's getting very annoying??
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: noisey radio
« Reply #1 on: 02 April 2011, 07:23:47 »
what radio ?
is it picking it up on FM ?
marvintpa
Re: noisey radio
« Reply #2 on: 02 April 2011, 10:23:33 »
In order to find out what is causing the interference you need to go back a bit.  Has the stereo always suffered from this ?  Did it suddenly start doing this ?  If it started, was this after something was changed, altered, repaired etc. on the car, or after you fitted something else ?
Re: noisey radio
« Reply #3 on: 02 April 2011, 10:30:29 »
Does the noise change if you turn on/off the heated rear windscreen ??
The aerial is actually the wires of the windscreen, if these break or get damaged it affects dreception. Can be fixed, sometimes, with conductive paint .. :)
jrchef
Re: noisey radio
« Reply #4 on: 02 April 2011, 23:00:54 »
the noise is on all stations the car radio SC 804 CD IS FITTED IN THE CAR FROM NEW.started about 2 weeks ago. the noise goes up and dow when you rev the engin, is there a suppresor some where? I can change.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: noisey radio
« Reply #5 on: 03 April 2011, 08:53:38 »
Clean alll the earth connections in the engine bay - anything on the engine and the body - seem to recall there is one under the battery that gets pretty corroded.
Not a definative answer, but a good place to start.
And no, there is no such thing as a simple suppressor to replace.
Radio & Decoding Technician
www.dndservices.co.uk
Re: noisey radio
« Reply #6 on: 03 April 2011, 11:41:35 »
If nothing comes of checking the ground connections, this could be the alternator starting to fail, so worth checking the charging voltage.
http://www.omegaowners.com/forum/YaBB.pl?num=1225724099
