Author Topic: Bluetooth ?????  (Read 6888 times)
robcad1972
  • Gillingham, Kent
Bluetooth ?????
« on: 25 March 2011, 09:42:53 »
Does anybody know of a bluetooth system that would integrate with a CDC2013, i have seen a few that apparently make use of the front speakers but obviously want to be able to stream music through all 8 using my existing Bose system.
Have tried many fm transmitters in the past but have found travelling around you end up with radio stations bleeding over.
Also by having the bluetooth means handsfree calling etc.
Cheers,
Bob.
If it ain't broke break it!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bluetooth ?????
« Reply #1 on: 25 March 2011, 09:48:16 »
Currently investigating the Autoleads iO system, but unsure if it will integrate with BOSE
Radio & Decoding Technician
www.dndservices.co.uk
Re: Bluetooth ?????
« Reply #2 on: 26 March 2011, 10:33:42 »
If you have the prewiring (if saloon, do you have aerial on roof?), a simple Nokia CW-7K (£20 from egay) is all you need (you may have to run a mic (easy) as not all cars come with one.
Autoleads do an adapter to make it easier, but not reqd really.
//Edit, above is for phone only, as the phone-in is mono and lo-fi.  For music, your only option on that is fm adapter, as has been covered umpteen times before
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bluetooth ?????
« Reply #3 on: 26 March 2011, 12:51:52 »
Doh !
I missed the obvious answer there didn`t I ?
Road Hog Mad
  • Cheshire
Re: Bluetooth ?????
« Reply #4 on: 26 March 2011, 19:00:55 »
my mates after market cd player has bluetooth he searched on his phone for the device which came up and then told his phone to auto connect to it and now he can make and receive and make phone calls when in the car through the stereo speakers.
Re: Bluetooth ?????
« Reply #5 on: 26 March 2011, 19:07:46 »
OP doesn't want a chavvy, non integrated stereo, and implies he wants to keep with the Bose setup ;)
Road Hog Mad
  • Cheshire
Re: Bluetooth ?????
« Reply #6 on: 26 March 2011, 19:40:12 »
not chavvy just up to date, niether of us are chavs, how very dare you. lol
robcad1972
  • Gillingham, Kent
Re: Bluetooth ?????
« Reply #7 on: 29 March 2011, 18:02:26 »
Many thanks for the replies.
The car has had a nokia kit in before, microphone is still beside rear view mirror and aerial cable is tucked up under glove box as i guess is the before mentioned socket which i believe is somewhere behind the glovebox.
I would like to keep the factory fitted unit as it has the sat nav and colour screen and obviously fitting an aftermarket unit  will require new speakers all round etc.
I have found an article on Parrots website which says that the new parrot i/o and mk 9200 or whatever the latest model is will stream to all four speakers but on cars fitted with Bose there has to be some kind of in line ballast/resistor or something??? obviously Dave will probably know more than me on this score.
All i'm trying to achieve is to be able to put my mp3 music files onto my mobile phone and be able to make/receive calls and be able to play my music through my existing stereo as obviously copied discs screw up the head unit so i don't want to go down that road :-?,
I did find on Egay a seller claiming to have the iso lead to suit but there was no sign of any major modification to support the Bose unit.
Re: Bluetooth ?????
« Reply #8 on: 29 March 2011, 18:28:08 »
You cannot do what you are trying. Accept that, move on ;)
The Aux in on the NCDC is lo-fi mono, so useless for music (its designed purely for phone, and won't be interruptable for satnav/RDS TP etc), and due to Bose, you cannot have devices that directly drive the speakers direct.
elitematt
  • Chelmsford, Essex
Re: Bluetooth ?????
« Reply #9 on: 09 April 2011, 01:23:31 »
I have got a Parrot Mki9200 in my omega, I also have bose.
It is a really good bit of kit although fitting it isn't cheap, the kit cost me around £200 I then found out i needed a cable which by passed the bose kit which cost £75.
It is worth it though, I have got a usb flash drive with all my tunes on it plugged into it or you can stream via bluetooth.
If you are not fussed about streaming music though this is a great handsfree kit, http://www.play.com/Mobiles/Mobile/-/1004/1249/-/3508739/Supertooth-Visor-Voice-Bluetooth-Handsfree-Kit/Product.html?searchtype=genre# ive had one of these for a few years now and ive only charged it about three times.
robcad1972
  • Gillingham, Kent
Re: Bluetooth ?????
« Reply #10 on: 10 April 2011, 22:13:38 »
Message for elite Matt could you tell me what lead it needed and where it came from, went into the local halfords today and got the usual wet behind the ears teenager claiming to be an audio expert who looked at me like i was foreign when i explained the 2ohm Bose system!!!! i am looking for the exact set up you have managed to aquire.
snookski
  • Bridgwater, Somerset
Re: Bluetooth ?????
« Reply #11 on: 10 April 2011, 23:26:03 »
I've got a Parrot CK3100 plumbed in to mine, works brill, through all speakers, but was already installed, when got the car, so no nothing about it, apart from how to use, external source is display on the m i d when in use
snookski
Re: Bluetooth ?????
« Reply #12 on: 10 April 2011, 23:30:26 »
sorry did'nt read through all posts, did'nt see you wanted music/mp3 played via bluetooth, will have a play with mine at some point
robcad1972
  • Gillingham, Kent
Re: Bluetooth ?????
« Reply #13 on: 11 April 2011, 18:18:09 »
I know i can put a bog standard hands free kit in with bluetooth but am looking for a kit that i can also stream mp3 through the bose system, am hoping i haven't got to tear it out!!!!!!
Re: Bluetooth ?????
« Reply #14 on: 11 April 2011, 18:43:18 »
In a nutshell, no.
With the bose speakers, only a Bose amp can drive them. The Bose amp uses 'odd' line levels. So your only option is via HU. Only the HU hasn't got a usable hifi stereo aux-in.
For the bose units, your options are based around FM modulators, or if you have ccr800, ccrt700, CCR2006, CCRT2007 or CCRT2008, a cassette adapter.
Live with it, move on.
