Author Topic: Air Con and external temp sensor  (Read 1648 times)
marcbucks
  • Milton Keynes, Buckinghamshire
« on: 23 April 2011, 12:26:12 »
Hi,
Probably a relevant question with the weather.
Omega B V6. The air conditioning has stopped working, the fan is on when button pressed to LO but can't hear the air con kicking in. I would obviously say replace the air con but the cars ext temp sensor reads around -13oC and car is smells like it running hot with engine temp getting upto 95o.
Could it be a warter/coolant system blockage affecting everything or a electrical fault with temp sensor.
I've not checked any fault codes as no engine warning light.
Any advice where to first look please
TY
Re: Air Con and external temp sensor
« Reply #1 on: 23 April 2011, 12:29:29 »
Engine temp is normal. Check wiring to temp sensor, under front bumper passenger side. May have to renew sensor, about £7 from VX
