Pages: [1] 2 3 4 5 6   Go Down
Author Topic: Fitting Sony H/U trouble  (Read 19145 times)
Ratty
  • Coventry
    • '99 2.5 CDX Mini-FL Est
« on: 04 August 2009, 20:22:10 »
Hi,
I tried to change my CCRT700 for a Sony MEX-1GP head unit, I have an adapter to allow use of the steering wheel controls and display, (a Connects2 DOPS004)
the trouble I'm having is marrying up the DOPS004 to the Omega's Harness.
The car connector
The DOPS004 connector
As you can see the connectors are different, anybody know how I can marry them up? an adapter maybe?
Thanks
« Last Edit: 04 August 2009, 20:29:07 by ratsalad »
John
Welung666
Re: Fitting Sony H/U trouble
« Reply #1 on: 04 August 2009, 20:26:03 »
You should be able to split the adapters longer plug off the clump and plug it in seperately
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 04 August 2009, 20:34:35 »
Er . . . .
 . . . . . Wrong lead   ::)
Just a thought though, and I may be mistaken on this, but I didn`t think the DOPS004 was compatable with the CCRT700 display ?
If I am wrong, then ask your supplier for the correct lead with Mini ISO terminals on it.
Radio & Decoding Technician
www.dndservices.co.uk
Ratty
  • Coventry
« Reply #3 on: 04 August 2009, 20:52:34 »
you're correct in that it isn't listed as being compatible with the CCRT700 but I'm removing that from the equation and going back to the main harness, and want to connect the DOPS004 to that.
@welung666:
I did think of that but the locating lug/catch is physically in the wrong place.
I used to have a sony unit in my old Miggy a '95 CDX and I had that working but for the life of me I can't remember how  :(
« Last Edit: 04 August 2009, 20:53:34 by ratsalad »
John
« Reply #4 on: 04 August 2009, 21:20:31 »
@welung666:
All the prefacelift omegas used a std (ish) iso 26 way connector apart from ccrt700 equipped cars that use iso 36 way connector.  Facelifts use 36 way ISO
Ratty
  • Coventry
« Reply #5 on: 04 August 2009, 21:29:14 »
So If I get a 36 pin ISO adapter to go with the DOPS004 it would work? Ive seen one but it lists it for a double DIN system, so wasn't sure  if it would work on mine.
http://cgi.ebay.co.uk/VAUXHALL-ISO-HARNESS-ADAPTER-CONNECTS2-CT20VX02_W0QQitemZ110410295815QQcmdZViewItemQQptZUK_Cars_Parts_Vehicles_Terminals_Cabling_ET?hash=item19b4f76a07&_trksid=p3286.c0.m14
« Last Edit: 04 August 2009, 21:43:26 by ratsalad »
John
« Reply #6 on: 04 August 2009, 21:32:14 »
You'd need to check wiring diagrams to see if the steering wheel connectors are in same place between ccrt and facelifts.  I guess its only steering wheel controls that you will use the top block for
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 04 August 2009, 23:02:57 »
Steering controls are on the lower 8 pin power part of the ISO block, and the three connections at the top are the data lines for the display.
But the reason that I have a doubt, is that the CCRT uses a completely different protocol language for the display, and to the best of my knowledge its far more involved than simply swapping a few wires around.
A CCRT700 does NOT use the same standard configured 36 pin Mini ISO block as used by the rest of the Vx Double DIN range, and the block advertised is for lower spec head units, CDR2005 / CCR2006 etc - CCRT700 does not have a solution available for doing what you are trying to do - you may need to downgrade the display itself
mathewst
  • Split, Croatia
    • v40
« Reply #8 on: 04 August 2009, 23:27:52 »
What excatly are you trying to do?Just get the radio working or the radio info on the display is important to you also?
« Reply #9 on: 04 August 2009, 23:32:31 »
Won't there be a Bose compatabilty problem too .....  ?  :-/  :-/  :-/
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 04 August 2009, 23:35:46 »
Oopps! Didn`t think of that one -
Sony would not be very forgiving at all if connected to a BOSE car
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #11 on: 04 August 2009, 23:37:34 »
Original post suggested both -    :-?
Ratty
  • Coventry
« Reply #12 on: 04 August 2009, 23:41:03 »
I would ultimately like to have the display and steering wheel controls working with the Sony, but it's not the be all and end all, if I can't get them working or at least the display part not working then I can live with it, tbh the steering wheel controls are more important to me. typical Vauxhall eh? ;)
John
« Reply #13 on: 04 August 2009, 23:43:42 »
I would ultimately like to have the display and steering wheel controls working ...... ,  ..... tbh the steering wheel controls are more important to me. typical Vauxhall eh? ;)
Put your CCRT700 back in then!  ;)  ;)  ;)  ;)
Ratty
  • Coventry
« Reply #14 on: 04 August 2009, 23:44:15 »
Forgive my ignorance here but what's the problem with Bose?
John
Pages: [1] 2 3 4 5 6   Go Up
