Author Topic: NCDC 2015  (Read 8063 times)
Dany
  • Belgium
NCDC 2015
« on: 03 May 2011, 17:32:46 »
I have found a NCDC 2015 in a car in the scrapyard... The guy told me that I can take everything what I need.
But that's my question, what do I need to make this headunit working on my car? Do I need to take the CID with the NCDC?
I already have a CID and a NCDC2013 on mine.
Thanks all! :y
Re: NCDC 2015
« Reply #1 on: 03 May 2011, 17:34:37 »
take it all, as CID will be paired to the 2015  :y
Dany
  • Belgium
Re: NCDC 2015
« Reply #2 on: 03 May 2011, 17:57:54 »
So only the 2015 and the CID? Anything else?
Re: NCDC 2015
« Reply #3 on: 03 May 2011, 18:12:55 »
Telematics unit Dany. Usually in the glovebox, and all associated wiring/loom/connectors you can remove. Get the GPS aerial if you can. £200 plus from GM. Handy as a spare :y
« Last Edit: 03 May 2011, 18:13:54 by RobG »
    • 530D M Sport, 330i Coupe
Re: NCDC 2015
« Reply #4 on: 03 May 2011, 18:56:03 »
Yes, as Rob says, everything you can! Head Unit, Head Unit cage including aerial plugs and length of cable, Telematics, Screen, as much of the looms as you can including the aerial flylead for the Telematics, The glovebox inner and the roof aerial and loom.
Dany
  • Belgium
Re: NCDC 2015
« Reply #5 on: 03 May 2011, 19:42:37 »
Ok! But I already have a telematics module with his plug (bought on egay!). It will works with this 2015? No pairing needed for the module? As I know only the headunit and the CID are paired right?
Re: NCDC 2015
« Reply #6 on: 03 May 2011, 20:33:58 »
Everything is paired and unless you have the Car Pass you will struggle to unpair any item.
Dany
  • Belgium
Re: NCDC 2015
« Reply #7 on: 03 May 2011, 20:42:15 »
EErrrfff so I have bought this module for nothing?
Re: NCDC 2015
« Reply #8 on: 03 May 2011, 20:44:46 »
Screen, Headunit and Telematics have to stay together unless you have the carpass to 'un-pair' them. They are bricks otherwise!
If you have the Headunit then TB may be able to help if you are able to ship Head Unit, Telematics and screen to him.....
Dany
  • Belgium
Re: NCDC 2015
« Reply #9 on: 03 May 2011, 20:54:42 »
I only have a telematics module that I have found on ebay at the moment (that I can't do anything with it!).
But I will get all the set so on the car on the scrapyard!
Re: NCDC 2015
« Reply #10 on: 03 May 2011, 20:58:12 »
If the donor screen is from a different engined / spec vehicle the screen will also need reconfiguring but this doesn't need the pairing code.  :y
Re: NCDC 2015
« Reply #11 on: 03 May 2011, 22:04:18 »
As VXL V6 says, NCDC, CD Changer, Display and Telematics are all paried to each other. They cannot be seperated unless depaired first, then repaired to their new components.
Re: NCDC 2015
« Reply #12 on: 03 May 2011, 22:30:47 »
And if you want to fit to your own car, which has 2013 and CID only, then you'll need an extra loom making to fit any telematics... ::)
Another customer for Andy.  ;)
If buying any of these components separately make sure they are de paired by the seller first or they are useless, that's the whole point of the security with these units.
Bit as said grab all you can Danny, they are as a set and worth money as such. Get the loom plugs as well, just cut them off. Tidy find. :y
Re: NCDC 2015
« Reply #13 on: 03 May 2011, 22:31:57 »
Already been having a chat!  :)
Re: NCDC 2015
« Reply #14 on: 03 May 2011, 22:34:26 »
If there's any documents in the car(unlikely) the car pass maybe there with security code.
