Pages: 1 [2] 3 4 5   Go Down
Author Topic: Bose - no sound  (Read 17024 times)
Re: Bose - no sound
« Reply #15 on: 24 April 2011, 20:05:00 »
Sound aside, does it work flawlessly?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Bose - no sound
« Reply #16 on: 24 April 2011, 20:06:42 »
You couldn't have dislodged the wiring under the parcel shelf could you?
TuBy's new whipping boy.
Re: Bose - no sound
« Reply #17 on: 24 April 2011, 20:15:43 »
Apart from no sound, I think its doing what it should, although I think the lack of radio stations is down to it losing the memory when I took the fuse out earlier.
I have taken the whole loom put from the parcel shelf today, took the amp out and brought it inside the car and then reconnected everything. I did this after the problem started, to see if there were any broken wires etc.
Dont suppose the amp has its own internal fuse ?
Re: Bose - no sound
« Reply #18 on: 24 April 2011, 21:43:41 »
Just thought of something else (which probably wont help diagnose anything ::)) it was behaving in a similar fashion a few days ago. I was wrking around the rear of the car and all of a sudden the sound came back by itself and the CD started playing. :-/
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Bose - no sound
« Reply #19 on: 24 April 2011, 23:24:45 »
Have you started to take this car apart yet?
If so the first thing you should have removed (after the electric front seats ::)) is the battery.
It's the only safe way to do it...
Re: Bose - no sound
« Reply #20 on: 24 April 2011, 23:41:04 »
As I said earlier in the thread, the battery had been removed. It has now been put back on so that I can test the Bose system.
Its difficult to do that without a battery. ;) ::)
Re: Bose - no sound
« Reply #21 on: 25 April 2011, 11:40:26 »
Ground connections? Cant remember if these are grounded locally, or via loom back to front of car
Re: Bose - no sound
« Reply #22 on: 25 April 2011, 12:29:56 »
Sounds possible. Would it be an idea to attach a wire to the case and to ground, or would it have to come from inside the unit ?
Re: Bose - no sound
« Reply #23 on: 25 April 2011, 19:49:02 »
Been having another fiddle with it todaY - checking connections etc. no joy though. Anyone know if the amp has an internal fuse?
Big_Al
Re: Bose - no sound
« Reply #24 on: 25 April 2011, 20:14:02 »
[/highlight]
Albs,I think an  earlier post said the speakers were humming. That would point to power amp being on & working but no input signal - would it not ? :-/ :-/ :-/
    • 530D M Sport, 330i Coupe
Re: Bose - no sound
« Reply #25 on: 25 April 2011, 20:39:34 »
I'd re-check all the connections - 36 Way ISO, Kickpanel connector, and Bose Connector. 0V is via the loom, not local to the boot area.
Another possibility is that you have a dead short or a short to ground on one of the speaker cables.
Re: Bose - no sound
« Reply #26 on: 25 April 2011, 21:01:11 »
[/highlight]
Your probably right Al. :y
Re: Bose - no sound
« Reply #27 on: 25 April 2011, 21:03:53 »
Have checked and rechecked the 36 way and kickpanel connector, cant see anything obviously amiss. Have checked rear speaker cables, but not the fronts yet. Dont know how I would check for a dead short ? :-/
Re: Bose - no sound
« Reply #28 on: 25 April 2011, 21:38:15 »
I wouldn't have thought it would be possible but is the amp connector in correctly? One end has a hook arrangement that has to be hooked in before the plug will go in squarely. I'm clutching at straws now!
Re: Bose - no sound
« Reply #29 on: 25 April 2011, 21:49:01 »
checked that. Took it out and reseated it to be sure. :(
Beginning to think ive knacked it somehow. :'(
Although, I also cant help thinking that in the process of removing various other electrical parts ive disturbed/ disconnected something to cause this. Although the syatem does mostly seem to be seperate from everything else. :-/
« Last Edit: 25 April 2011, 21:51:10 by albitz »
Pages: 1 [2] 3 4 5   Go Up
