Author Topic: boot lock  (Read 2939 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
boot lock
« on: 07 May 2011, 11:19:07 »
hi all
got a problem with the mv6 bootlock  :( the problem being is that it wont open or lock with the central locking , anything i can look at ?  or what do i have to change ?
tia :(
Re: boot lock
« Reply #1 on: 07 May 2011, 22:31:27 »
hi all
tia :(
What position is the lock in? Vertical or horizontal, one way locks & un-locks with the central locking, the other stays locked irrespective of the central locking. Can't remember which way is which though  :-/ ;)
Re: boot lock
« Reply #2 on: 07 May 2011, 22:43:10 »
hi all
tia :(
Already told Rog that via PM ;D
fiend61
  • york
  • each to their own
Re: boot lock
« Reply #3 on: 07 May 2011, 22:47:35 »
cheers andy nice to have a 2nd opinion  ;)
 :P rob  ;D ;D ;D
Re: boot lock
« Reply #4 on: 07 May 2011, 23:35:39 »
 :P rob  ;D ;D ;D
trouble is, the locks suffer the same fault as the driver's door lock ........ they never get used & seize up. You might need a bit of lub in there.  ;) ;)
fiend61
  • york
  • each to their own
Re: boot lock
« Reply #5 on: 08 May 2011, 09:27:10 »
many thanks rob and andy  :y
it was key position  :-[
for peoples info the lock should be in the horizontal position for the central locking to work not vertical  :y
Re: boot lock
« Reply #6 on: 08 May 2011, 09:48:41 »
Nice when the fix is easy Rog :y ;D :D
fiend61
  • york
  • each to their own
Re: boot lock
« Reply #7 on: 08 May 2011, 10:03:39 »
tell me about it rob  :)
pity i had already stripped boot lining out  :D
all i have to do now is my mates fuel pump, crank sensor, waiting for info on fuel pump post  :y
Re: boot lock
« Reply #8 on: 08 May 2011, 21:05:43 »
Please read the manual then ................  ::) ::) ::) ::) ;)
fiend61
  • york
  • each to their own
Re: boot lock
« Reply #9 on: 08 May 2011, 21:15:57 »
my god there is a manual on these crappy great cars  :o :o :o
Re: boot lock
« Reply #10 on: 08 May 2011, 21:21:41 »
you might have saved yourself the effort of removing the lining from the boot lid.  ;) ;) ;) ;)
Did you never wonder why there were 2 positions for the lock?  ::) ;)
fiend61
  • york
  • each to their own
Re: boot lock
« Reply #11 on: 08 May 2011, 22:05:53 »
in all honesty rob i didnt  :-[
Re: boot lock
« Reply #12 on: 08 May 2011, 22:41:35 »
You realise you said that out loud?  ::) ::) ::)
