current drain f7
Started by denisaok, 05 May 2011, 21:32:08
Dave DND
Next job for you -
Check your meter !!  0.49A is far too high, and would drain a battery - should be around the 50~70 mA or so, not approaching 500mA.
The next few days will tell - if your battery remains fully charged, then your meter is innaccurate
Radio & Decoding Technician
www.dndservices.co.uk
QuoteNext job for you -
Agreed. I'm starting to wonder if it's reading 49mA, which is nothing to worry about. :y
denisaok
#17
Hi Guys
Thanks again for the help this is how I got my reading I set the meter to 10A on the dial and got the reading of 0.49 so would that be mA .
So do I have anything to worry about ?  ::)
To ask a question and feel idiotic for a moment is better than not to ask and be idiotic for a life time.
Martian
#18
If you got a reading of 0.49 when on the 10A range, that is 490mA (which is way too high).
denisaok
Thanks
Well started at 2.4 so am getting there looks like Ill be pulling circuits this weekend. :'(
Any advice on where to start :-?
Martian
Start at F1 and work your way through.
denisaok
Thanks Martin
Done that Fuses 6 & 7 seem to be the the problem
Martian
QuoteThanks Martin
Don't have a manual so I can't help you with what is fed by those fuses, I'm sure someone else can though.
QuoteThanks Martin
http://images.omegaowners.com/documents/UserGuides/OmegaOct2002.pdf
page 186
Martian
#24
Thanks for that Andy.
Denisaok,
There isn't much on those 2 circuits, and if I had to pick what to blame first, I'd be looking at the radio (F6).
What does the quiescent current drop to with F6 only removed?
PS
I take it you have checked that your meter is telling the truth to start with?
Dave DND
I would advise that a 10A setting on a meter is not going to be sensitive enough to measure accurately a small reading of 50mA
I would obtain another meter before going any further
Martian
QuoteI would advise that a 10A setting on a meter is not going to be sensitive enough to measure accurately a small reading of 50mA
Pretty much all the "diy" DMM's will struggle with reading 50mA or so on the 10A range, but if the OP gets a reading of zero (or near) after seeing 490mA then that will be enough to show them they are on the right track.
One thing I would do though is verify the accuracy of the DMM as you suggested earlier, the cheap ones do produce some weird & wonderful "results" when the battery starts to get low (such as over reading).
denisaok
Hi All
I will use my mates meter his a TV engineer an coming to give me a hand on Saturday. I got a tis 2000 today to help trace circuits will keep you posted
denisaok
Hi all
All sorted now turned out that the 1st delay relay I tried was faulty to.
