Author Topic: F/L Elite  (Read 3626 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: F/L Elite
« Reply #15 on: 30 May 2011, 08:30:23 »
Looking At it another way, as I find it easier to explane....
Take a 2015 with screen and telematics. All 3 are "paired" using the security code and tech2.
If you depair the telematics you then have 2013 software on your 2015 head unit. The print on the facia is the only hardware difference, while the software changes the red and green phone buttons function to "home" destination on the sat nav.
The problem you 'll have upgrading to 2015/adding telematics is the loom plug won't be present, and the unit all but fills the glove box. Blutooth is a far easier answer and arguably more convenient.
Having said all that it is possible to have the loom plug added, and hence the telematics unit relocated to e.g. the boot Bose shelf/first aid cupboard/Carin cage.
CID as a good enhancement over the GID. It's more clear and makes the software easier to use. Recommended!
But as said, any CID  unit purchased for retro fitting MUST MUST MUST  be depaired from it's original head unit, and hence in DELIVERY MODE in order be usable! Otherwise it is useless.
Steering wheel controls completely replace the stalk buttons btw, which are no longer needed. Takes a bit of getting used to, but it's far better IMO. Be aware In some modes some steering wheel buttons have no function. ;)
Thats very helpful Chris, I'll look out for a paired set or a depaired CID. Cheers mate. Oh and when I find one, I'll bring it along for fitment. heh heh heh! ;D ;D ;D :y :y :y
Shackeng
  • Ramsbury
Re: F/L Elite
« Reply #16 on: 30 May 2011, 08:32:15 »
Will any NCDC2013/2015 CID, properly paired or depaired as applicable, transplant OK?
« Last Edit: 30 May 2011, 08:33:04 by ci643215 »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: F/L Elite
« Reply #17 on: 30 May 2011, 16:58:10 »
I can put this version of CID back into delivery mode if it is of any help
http://www.dndservices.co.uk/vauxhall-cid-display-kj.html
Radio & Decoding Technician
Shackeng
  • Ramsbury
Re: F/L Elite
« Reply #18 on: 30 May 2011, 17:11:47 »
Thanks Dave, I'll keep that in mind.
Chris :y :y :y
