Author Topic: hid headlights  (Read 2622 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
hid headlights
« on: 04 June 2011, 14:26:33 »
just brought 2 headlights complete with ballasts want to know if it is hard to wire in as mine are just standered light units any help would be greatful. ian :)
Re: hid headlights
« Reply #1 on: 04 June 2011, 14:41:57 »
I assume you bought the ballast connectors with a short piece of loom with the Hid`s :question. If yes, swap your level motors onto the hid`s (plug & play), two wires from ballast connectors (should be brown & yellow), splice them into your existing loom that carries the dip beam connector.
plym ian
  • Plymouth, Devon
Re: hid headlights
« Reply #2 on: 04 June 2011, 14:57:48 »
is that the bit that goes to the bulb :question
Re: hid headlights
« Reply #3 on: 04 June 2011, 16:16:27 »
Nope. You need the connector & piece of loom that plugs into the ballast...........the bulb is fed from the ballast
« Last Edit: 04 June 2011, 16:26:00 by RobG »
plym ian
  • Plymouth, Devon
Re: hid headlights
« Reply #4 on: 04 June 2011, 16:46:51 »
didn't get that bit but have got an hid kit that the ballasts have gone. looks like that sort of connection so i'll try that. cheers ian :)
plym ian
  • Plymouth, Devon
Re: hid headlights
« Reply #5 on: 04 June 2011, 20:36:40 »
Tried the connector I had but didnt fit :( :(
Re: hid headlights
« Reply #6 on: 04 June 2011, 20:38:25 »
Are the ones in my pic the correct connectors :question
plym ian
  • Plymouth, Devon
Re: hid headlights
« Reply #7 on: 04 June 2011, 21:09:37 »
They look like the right ones its just the ones I've got doesn't fit cause they are from an after market kit that i thought might fit
Re: hid headlights
« Reply #8 on: 04 June 2011, 21:14:37 »
Fiver posted if you want them Ian
plym ian
  • Plymouth, Devon
Re: hid headlights
« Reply #9 on: 04 June 2011, 21:24:49 »
Ok pm me cheers rob :) :)
Re: hid headlights
« Reply #10 on: 04 June 2011, 21:31:06 »
PM sent :)
