Pages: [1] 2 3  All   Go Down
Author Topic: Mic in interior light?  (Read 8397 times)
tangocat
  • Newcastle Upon Tyne
« on: 01 May 2011, 19:14:54 »
Hi while changing a bulb i noticed what looks to be a microphone in the center of the front interior light
first question is Is it?
second if it is can it be used insted of the nokia one with my hands free  kit?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Mic in interior light?
« Reply #1 on: 01 May 2011, 19:27:54 »
Yes, and probably yes or fit your nokia one in there.
Chris.
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #2 on: 01 May 2011, 19:31:39 »
Its definitely a MIC with the phone kit (if you still have the phone dock).
But if you want to use another phone/handsfree kit, then it will most prob come with a MIC?  :y
tangocat
« Reply #3 on: 01 May 2011, 19:46:29 »
the nokia one i have is way to big to fit and the one fitted to the car has 4 wires i think so unsure which wires to use any ideas??
Stallion
  • Romford
« Reply #4 on: 01 May 2011, 19:51:45 »
4wires? loose or connected to the rear of the dock!
tangocat
« Reply #5 on: 01 May 2011, 19:54:49 »
Dock?? the mic has a multi plug affair with i am sure 4 thin wires plugged in to it no other signs of a phone ever being in the car
Stallion
  • Romford
« Reply #6 on: 01 May 2011, 20:11:25 »
AFAIK, the wires should lead to a unit behind the glovebox, the 4wires coming out from that unit:
1-mic 2-speaker (phone brand) 3-power 4-mute(stereo)
Just a thought for flexibility you can look into bluetooth car kits? (iv got a nookia ck-7w)  :y
tangocat
« Reply #7 on: 01 May 2011, 20:15:42 »
my hands free is a ck7w also just thought if i could i would use the factory fitted and hidden away mic
Stallion
  • Romford
« Reply #8 on: 01 May 2011, 20:20:59 »
Just realised for some reason i didnt end up using the original mic (didnt fit or something) so ended up using the mic that came with the CK-7w!
tangocat
« Reply #9 on: 01 May 2011, 20:24:05 »
yeah the mic for the nokia kit has a jack plug connection i was thinking of chopping and soldering just hopeing some one had done it before
Stallion
  • Romford
« Reply #10 on: 01 May 2011, 20:25:56 »
oh sorry, i didnt go through that *chopping* route unfortunately!  :y :y
« Last Edit: 01 May 2011, 20:26:40 by Stallion »
tangocat
« Reply #11 on: 01 May 2011, 20:29:13 »
no probs cheers for the help might give me something to work on
« Reply #12 on: 01 May 2011, 20:41:59 »
Facelift mics can be used with Nokia carkits - simply use the prewiring plug taped above glovebox.
Mics fitted to CCRT700 equipped cars cannot be used with Nokia kits
tangocat
« Reply #13 on: 01 May 2011, 20:50:21 »
Thank you TB will have a look in the morning if i get the chance
Stallion
  • Romford
« Reply #14 on: 01 May 2011, 20:55:19 »
 :question :question :( :-? I didnt find such wiring in mine, unless it was used and taken out in the past  :'( :-/ Lucky You TC
« Last Edit: 01 May 2011, 20:55:51 by Stallion »
Pages: [1] 2 3  All   Go Up
Page created in 0.533 seconds with 20 queries.
