Author Topic: Bose - again  (Read 2805 times)
Bose - again
« on: 06 June 2011, 20:44:06 »
Three wires which come from the multiplug at the rear of the headunit-
Black -labelled as mute on the diagram
Blue labelled as TL+ on the fdiagram
Brown - labelled as TL- on the diagram
They dont go to the main Bose loom but go into the main loom towards the n/s of the car. They have been chopped when I was removing some other component. Any chance they might be connected the the lack of any sound from the system ?
Tia.
Re: Bose - again
« Reply #1 on: 06 June 2011, 20:46:46 »
suspect they went to prewiring for phone.
No, wont affect it, unless the mute is shorting down, thus giving 'External Audio' on CID
Re: Bose - again
« Reply #2 on: 06 June 2011, 20:49:15 »
......... you wish Albs ;D ;D
Re: Bose - again
« Reply #3 on: 06 June 2011, 20:51:06 »
I think I will now probably have to accept that its got a problem that Im not going to solve. :(
I would at least liketo know if its the headunit or the amp. :-/
Re: Bose - again
« Reply #4 on: 06 June 2011, 20:55:40 »
Has LD got a 2013 in his new baby :question
Re: Bose - again
« Reply #5 on: 06 June 2011, 20:58:40 »
Now theres a thought. ;) :) ::) :-X
Re: Bose - again
« Reply #6 on: 06 June 2011, 21:00:27 »
You won`t get nowt on his display but I would have thought if your HU is OK you should get sound, unless someone posts to the contrary ::) :D
Re: Bose - again
« Reply #7 on: 06 June 2011, 21:02:51 »
yes, you will get radio, along with annoying bleeps every 5s
Re: Bose - again
« Reply #8 on: 06 June 2011, 21:03:39 »
That`ll be Albs cursing ;D ;D
Re: Bose - again
« Reply #9 on: 06 June 2011, 21:04:10 »
Is the amp getting power? Amp is seperate fuse to HU
Re: Bose - again
« Reply #10 on: 06 June 2011, 21:12:34 »
Know which fuse ?
I would have thought it would maybe be easier to try "an other " amp plugged into my headunit rather than swap headunits over ?.......if the amp is from an estate that is ? :-/ ;)
Re: Bose - again
« Reply #11 on: 06 June 2011, 21:15:05 »
Have you checked fuse #6
Re: Bose - again
« Reply #12 on: 06 June 2011, 21:17:33 »
I think so, will look again in the morning.
