Author Topic: CC2006 dropping out  (Read 8330 times)
VR4Dave
  • Lincoln
CC2006 dropping out
« on: 13 June 2011, 20:03:21 »
When on radio or cd player the stereo intermittently "drops out" if it was just on cd I would say it is exactly like a scratched disc.
Any ideas?
TIA
Re: CC2006 dropping out
« Reply #1 on: 13 June 2011, 20:16:36 »
Shorting speaker causing temp amp shutdown?
VR4Dave
  • Lincoln
« Reply #2 on: 13 June 2011, 21:14:42 »
Thanks, how do I check for this my electrical knowledge is limited to say the least. :-[
VR4Dave
  • Lincoln
« Reply #3 on: 14 June 2011, 13:58:22 »
anyone  :(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 14 June 2011, 15:09:31 »
Disconnect each of the speakers in turn and see if the problem stops
Thats about all you can do with an intermittant fault such as that when the speakers are suspect
Radio & Decoding Technician
www.dndservices.co.uk
VR4Dave
  • Lincoln
« Reply #5 on: 14 June 2011, 21:14:20 »
that sounds a bit obvious, thanks will do.  :-[
VR4Dave
  • Lincoln
« Reply #6 on: 17 June 2011, 14:30:41 »
I disconnected the speakers each one in turn and made no difference.
When I had disconnected the last one I reconnected the one in the boot and It was still dropping out  :'(
I forgot to mention it's a bose system if that makes any difference.
Any more ideas?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 17 June 2011, 17:22:37 »
Yes, makes a big difference.
 :-X
VR4Dave
  • Lincoln
« Reply #8 on: 17 June 2011, 17:45:52 »
I suppose that means that it's a common issue and easy and cheap to fix  ;D ;D
VR4Dave
  • Lincoln
« Reply #9 on: 18 June 2011, 05:28:22 »
bump  ;D
VR4Dave
  • Lincoln
« Reply #10 on: 20 June 2011, 15:58:40 »
Now my fists of ham have struck again!  I reconnected the speakers and I only seem to have the boot speaker, rear passenger and front driver working  :(
Don't see what I've done wrong, please help.
VR4Dave
  • Lincoln
« Reply #11 on: 20 June 2011, 21:35:55 »
Took speakers out again and refitted they're all working again now.
But there is something strange about the rear drivers side door speaker.
I had the radio on when I was reconnecting and when I offered it to the door it kept cutting out, with a bit of fiddling it is fitted and working ok.
What I don't understand is why it would do this the connections look clean and sound.
Any ideas? is it worth replacing this speaker? I don't think it's the cause of the "dropping out" as it was still dropping out on the other speakers when this one was disconnected.
Could it be the wiring for this speaker rather than the speaker itself?
« Reply #12 on: 20 June 2011, 21:41:46 »
Sounds a bit similar to the 2013 setup I have. Sound was dropping out intermittently, and then dropped out altogether.
I havent as yet got to the bottom of it (its no longer in a car) but if I do I will post up and let you know.
The only realistic option I have left is to try the H/U in another car to try to narrow it down - hopefully.
VR4Dave
  • Lincoln
« Reply #13 on: 20 June 2011, 21:56:54 »
Can I just pop it into another car or does it need pairing or is it just coded? (really crap with electrics!)
« Reply #14 on: 20 June 2011, 22:09:40 »
Im probably worse. I tried it in my own car, but it isnt Bose equipped, so the fact that it didnt work didnt enlighten me very much.
If your doesnt have a seperate amp (as the 2013 does) you might have a better chance, but to be quite honest - I aint got a fackin clue what Im talking about on matters connected with electrickery. ::) ;D
