Author Topic: Ignition switched live feed under bonnet needed ?  (Read 1622 times)
Shark1e
  • Stoke on Trent
    • Meega 2.5TD-CD Estate
« on: 02 July 2011, 15:14:01 »
Hi all,
can anyone tell me if they know off their head if there is a live feed under the bonnet that is switched by the ingnition on / off etc, i have led lights in my grills next to bottom fogs and want them to be on once the engines running and not only when i put side lights or main lights on.
don't want to have to drag wires through bulk head from fusebox so just wondered if there was such a feed local under the bonnet?
thanks rob
2.5 cdtd omega 1999 manual estate Chipped and poorly at the moment -  is there a doctor in the house
Re: Ignition switched live feed under bonnet needed ?
« Reply #1 on: 02 July 2011, 18:44:50 »
Hi all,
thanks rob
IIRC the live feed from the alternator is blue/black, you'd use it to power up a caravan split charge relay/etc. It'll be live when the engine is running ie not just ignition live.
Shark1e
  • Stoke on Trent
« Reply #2 on: 02 July 2011, 20:01:19 »
Urrrm nice will test it
Thanks mate
