Author Topic: Airbag fault light.  (Read 7827 times)
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Airbag fault light.
« Reply #15 on: 03 July 2011, 11:29:35 »
Whenever messing with airbag systems I would strongly advise disconnecting the battery ;)
It is the best thing to do, disconnect the battery and then go and have a smoke/cup of T to allow any residual current to dissipate...
If you can't be bothered to do that then you should be aware that if you turn on the ignition whilst any part of the srs is disconnected then you will get a light on the dash that needs re-setting.
« Reply #16 on: 03 July 2011, 21:37:03 »
When messing with airbags with cheap chinese code readers, I get out of the car ;D
« Reply #17 on: 03 July 2011, 22:11:19 »
The only thing I did was clear the dtc's... Refused to go any further!
« Reply #18 on: 03 July 2011, 23:36:42 »
woose! :P ;D
rossi123
  • St Helens Lancashire
« Reply #19 on: 09 July 2011, 20:22:46 »
Well first thanks for the help but I'm afraid to inform you all that this particular fault was not cured with the instructions albs gave me when i followed instructions it did clear the child seat fault but it just created another one that the circuit pad has a fault so back to the drawing board :(
« Reply #20 on: 09 July 2011, 23:40:42 »
Iirc mine said seat pad fault - thats where the child seat occupancy sensor is. :-/
rossi123
« Reply #21 on: 10 July 2011, 00:18:45 »
Yes mine is the same but when I unplug it like you said to do then it comes up with another fault instead of getting rid of the initial problem, I'm beginning to think its a wiring issue because I can't see why the procedure what you have told me shouldn't  work so it's back to square one with it Im afraid :(
« Reply #22 on: 10 July 2011, 07:52:41 »
What is the new fault which shows up ?
rossi123
« Reply #23 on: 10 July 2011, 09:54:56 »
Although I can't exactly tell you the words where, seat pad circuit fault, so god only knows
« Reply #24 on: 10 July 2011, 10:21:40 »
So youve unplugged the sensor, and the old code went but a new one has appeared, is that right ?
On mine, I unplugged the sensor, cleared the fault code, and (after a couple of starts iirc) the light went out.
I presume your using a Chinese code reader, which we are not allowed to mention on here due to copyright laws ?
rossi123
« Reply #25 on: 10 July 2011, 10:29:47 »
Ahhh I shall try that then, hopefully that will work [ch57431]
h4nter
  • Poland
    • Omega B FL 2002 3.2 V6
« Reply #26 on: 03 January 2012, 16:21:23 »
Thanks guys for posts and information but still for a month I have no clue how to fix this stupid Child Seat Detection Sensor.
I get the information on polish forum.omegaklub.eu that using original Tech2 in official Opel Car Service they can deactivate this sensor. So I went there, they charged me ~50euro for 1h "computer diagnostics" and said that they can not reprogram my airbag module :(
When I try with my "My Naff Code Reader" to change CSD sensor for Not In Use I get "programming failed". That's why I get to official Opel Service. 50euro for nothing.
So I tried your suggestions. I disconnected yellow flat connector, cleared in "My Naff Code Reader" the error codes, then refresh codes list and then I get "Seat Occupancy Pad 1 Not Present", but there is no CSD Malfunction error. I cleared the connection pins, put some WD40 and tied strongly the connector and then tried again to clear the codes. Now the situation is the same as at the beginning. I see only CSD sensor malfunction.
As far as I know, in the passanger seat there is inside this seat occupancy pad (like a rubber keyboard) with some chip + sensor for Child Seat Detection. It is all on 3 wires (yellow flat square connector). So whenever I disconnect this yellow connector and clear codes, I don't get CSD malfunction but the whole Occupancy Pad is Not Present. So it won't fix my problem but create bigger one. Am I missing something?
Summary for the moment:
- I'm unable to deactivate CSD sensor in "My Naff Code Reader"
- Opel Car Service (official) is unable to deactivate CSD sensor in Tech2 (or they don't know how)
- messing with Occupancy Pad/CSD sensor yellow flat square connector doesn't help
If only someone could describe his procedure step by step and on which Omega version it was done. Or some other suggestion/advice.
Mine is Omega B FL 2002 3.2 V6 Y32SE Executive caravan/combi.
« Last Edit: 03 January 2012, 16:30:40 by h4nter »
Page created in 1.546 seconds with 20 queries.
