Author Topic: Useless with ICE - help!  (Read 2956 times)
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« on: 09 July 2011, 18:35:51 »
Hiya fellas,
As per title got an ICE issue of which i know bugger all about. My car has the CCR6000 head unit with a Sony CDX T-69 CD Autochanger in the boot. The changer is goosed and this may sound a right numpty question but do most CD changers have the same leads :-[ Mine has a red and a white jack plug with a 3rd round connector (looks like 3 contacts in the end). So really the advice i need is.....do i go to Hellfrauds, buy a like for like off fleabay or contact one of the guys breaking an Omega.
Cheersin advance for any help  :y
Those are my principles, if you don't like them I have others.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Useless with ICE - help!
« Reply #1 on: 11 July 2011, 10:01:56 »
Ok,
A few questions
1 - are you sure its a CCR6000 as the model number does not appear to be correct?
2 -  How are you controlling the CDX-T69 ? Through an FM modulator, or do you have  a seperate interface box fitted?
3 - What is the fault you are experiencing ?
FYI, No ! - leads and protocols are very different, but would need to understand the setup you have before alternatives could be suggested
Radio & Decoding Technician
www.dndservices.co.uk
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #2 on: 11 July 2011, 11:06:15 »
Hiya Dave,
1. Errrr yup, its wrong....should be a CCR600  :-[
2. Have no idea, its just the leads which connect to the CCR600.
3. It just will not work......will not eject CD magazine.
All i know is the 3 leads i have available - 1 red jack, 1 white jack and the 3rd round one with 3 contacts in it. Don't think i'm very good with the info you need - ICE??, i'm shite at it!
Thanks for the info re others multi-changers. :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 11 July 2011, 14:19:14 »
Ok, daft question, but has it ever worked, or is the car new to you and you are trying to use it for the first time?
« Reply #4 on: 11 July 2011, 18:29:19 »
I thought only (some) CDC2s and correctly configured CDC3s worked with CCR600  :-/
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #5 on: 11 July 2011, 20:14:23 »
Not a daft question at all fella. The car is new to me & the changer has not worked in the time i've had it. :y
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #6 on: 11 July 2011, 20:17:38 »
Sorry fellas, been a bit of a plum & forgot to add that when i select the CD changer the display reads "ER --3---" then reverts back to the radio :y
« Reply #7 on: 11 July 2011, 20:18:45 »
That could explain a lot ;)
I suspect you need a CDC2 (beware, there are different, incompatible types of CDC2 that look identical)
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #8 on: 11 July 2011, 20:24:57 »
A CDC2  :-? Thats a complete David Seaman to me (straight over my head). What would a CDC2 be...? :-/
« Reply #9 on: 11 July 2011, 21:39:51 »
The Blaupunkt CDC2 that is fitted to Vauxhalls with ccr600.
Beware, there are different versions.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 12 July 2011, 08:16:15 »
Ok,
My best guess is that the Sony Changer may not actually be connected to your stereo, and is left over from a previous install. There was an interface that went behind the head unit to allow use of a Sony changer on a Vauxhall head unit, but it was dropped virtually as soon as it was launched due to compatability issues - to find one nowadays would be like finding some rocking horse poo.
I reckon if you follow the Sony changer wires back through the car, they may not be connected to anything.
Suggest to go one of two ways from here - either find a Sony head unit and connect your changer to it, or find the correct version of Blaupunkt CDC2 changer and plug that in.
Should you actually find an interface box, then its almost certainly failed
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #11 on: 12 July 2011, 15:53:30 »
Ok,
Thanks for the advice, i'm guessing that if i need a CDC2 then i would also need a new head end connector and lead set?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 12 July 2011, 18:25:31 »
I bet the original leads are still in there, as they are a real bugger to remove !!
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #13 on: 12 July 2011, 19:50:14 »
Ahhhhhh, will get looking :). Where would the tail ends tend to be normally? Glovebox, left or rear storage cubbies in boot :-/
TB also mentioned there are 2 different types of CDC2....how can i tell which one i need?
Cheers
« Last Edit: 12 July 2011, 19:50:52 by sticka_v8_init »
