Author Topic: headlight message on dash  (Read 2368 times)
shadwell1981
  • leeds, west yorkshire
  • welsh man in town!!
« on: 11 July 2011, 21:38:27 »
i have read many posts but i still have no clue how or where to start.
low beam fld/ vison is diplayed on the computer display (2000 w reg cdx estate) do i need to strip light to change leverler motor or the adjuster pins that break. all lights are working except o/s front fog light.
Re: headlight message on dash
« Reply #1 on: 11 July 2011, 21:53:38 »
... do i need to strip light to change leverler motor or the adjuster pins that break. all lights are working except o/s front fog light.
You have a fault with either the sensors on the front near side wishbone or rear nearside radius arm or either of the levelling motors in the headlights. A common fault is the sensor on the fns wishbone becoming detached. Despite a recent post, knackered plastic adjusters will not display this message because the headlight levelling system has no way of knowing where the lights are actually shining.  :y :y :y
A code reader will take the guess work out.  ;)
tango
  • brum
« Reply #2 on: 11 July 2011, 22:42:37 »
Most likely cause is the sensor on the front passenger side wishbone
Check if it hasn't become detached also if it's connected it could be stuck so quick spray with wd40 should get thinks moving again
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #3 on: 12 July 2011, 07:12:15 »
And the main cause seems to be that the ball joint on the wishbone end gets stuck, usually sand or small stones blocking its movement and therefore the other end has to move "more than it is designed to" and the ball from sensor itself comes off. And once this has occured it will not keep in properly. Poor german design  :-X
Kaycee
  • Doncaster
« Reply #4 on: 12 July 2011, 08:39:51 »
Mine did this after hitting pot hole i tied it on with Plastic Tie wrap
There is a tide in the affairs of man if taken at the flood will lead on to greater things
shadwell1981
« Reply #5 on: 14 July 2011, 22:20:49 »
had a day of playing with car today, took off wheels and cleaned both sensors. happy to report they not fallen off or damaged. fitted all back up, turned car on and still had the so and so message! started stripping light units out but think i need the control box that makes the lights move on the light
should they make a noise or is it a case of take one off and replace with new item and if nothing happens, try other side?
« Reply #6 on: 14 July 2011, 22:46:58 »
You're guessing. You need a code reader to tell you what the fault is.  :y
