Author Topic: Replacing the laser CDC2013  (Read 3119 times)
« on: 14 June 2011, 21:16:19 »
This site ...
http://www.lasertrader.de/english/
lists
Optical laser pickup for Opel NCDR1100 NCDC-1300 1500 2011 2013 2015
- NCDR 1100
- NCDC 1300
- NCDC 1500
- NCDC 2011
- NCDC 2013
- NCDC 2015
for 38 euros + delivery.
My CDC2013 keeps spitting out the Nav CD even though it is a genuine CD, I understand this to be symptomatic of a knacked laser due to the use of the "copied disk" that was in when I got the car.
Question is .... how easy is it to actually change that item....?? I'm reasonable at DIY and have built a few PC's .. working at component levels..... but have little "real" electronics experience, I can solder the odd connection but would run away from soldering a motherboard.
Would taking the unit out, replacing the laser, then replacing the unit have any detrimental effect on the "pairing" of the bits and bobs  ??
    • 530D M Sport, 330i Coupe
Re: Replacing the laser CDC2013
« Reply #1 on: 14 June 2011, 21:21:11 »
Nothing will affect the pairing on the replacement.
The laser swap is fiddly (disassembling the mechanism) but do-able, no soldering as the ribbon cable just clips into the connector. I have three here i've got to do. my test one didn't go too well but was good practice if nothing else.
Once fitted you need to cut a solder tag off the ribbon cable (easy).
I will be doing a guide at some point but need to refine the process before I document it.
« Last Edit: 14 June 2011, 21:23:40 by VXL_V6 »
« Reply #2 on: 14 June 2011, 22:07:23 »
That's a tad worrying ... if YOU can get it wrong .. what chance do I have !!!  :( :(
Perhaps I should buy one and wait until you have written the guide before I attack the car !!
« Reply #3 on: 14 June 2011, 23:19:56 »
My mistake was to try and re-assemble the mechanism when I was tired so managed to catapult one of the springs off never to be found again.
I also manipulated the mechnism full travel to see how it worked....  ::) Opps
Welsh Dan
« Reply #4 on: 14 July 2011, 20:06:52 »
Is it the same laser for both the CD changer and Navi ( as in will that replace both lasers)?
« Reply #5 on: 14 July 2011, 22:01:10 »
No
« Reply #6 on: 14 July 2011, 23:30:51 »
Got one to do here. Better get me arse in gear and buy the laser I suppose.  :-[
« Reply #7 on: 15 July 2011, 08:01:36 »
Not to hard to do, done a few with 100% success (including SP32's)
