Author Topic: !!Help!!! elite electrics or is it haunted????  (Read 1985 times)
biggsy
  • Rosyth
« on: 16 July 2011, 00:05:47 »
Hi troops could do with a little direction here with my electrics  :-/(omega elite 2000)
so here we go first illl list the probs then ill list what i have done so far :-? as i am wondering if there is a common earth or wire to all of the below my tester is duff so bear with me  ::)
my n/s electric window will not work from the passanger switch
my n/s puddle light will not illuminate
my near side passenger vanity mirror will not illuminate
my n/s elctric chair has a dance now and then and the sunroof likes to join in the merryment too :D
now then!!! what i have done so far is clean all connections on the seat and the sunroof with eleckie cleaner sand paper etc this has so far anyway proven to rectify the dancing issue  :y
on to the current issues :(
stripped door cleaned all connections in door checked wiring loom for obvious breaks
 (no change)
replaced puddle light with working spare (no change)
swapped electric window switch with friends that is working
and my existing switch works fine in his car so (no change)
replaced bulbs in visor (no change)
both the electric window and mirror work fine from drivers side switch therfore regulator and motor in passenger door fine oh and disconnected and cleaned door connector and the liitle push switch however i am guessing that is fine as
it works the interior light ok.
I know wiring can be a nightmare however if one of you has suffered from similar problems any tip would be greatly appreciated. :-[
My friends tell me my car is haunted  :D ;D however as i am out of holy water and unlike christine it dont fix its self  :D ill stick to the wd40 water :o
Thanks guys
Ron ;)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: !!Help!!! elite electrics or is it haunted????
« Reply #1 on: 16 July 2011, 08:04:33 »
1- probally duff switch try with a known working one
2- check for breaks in cable where it goes into door, you need to get your meter
3-unscrew sunvisor and check its still plugged in, need meter again to check for voltage
4-no idea, but must be funny  :P
5-sunroof take apart and clean the disc as per guide on here then reset
biggsy
  • Rosyth
« Reply #2 on: 16 July 2011, 10:07:37 »
Thanks fiend  ;)
Have tried most of them [smiley=dankk2.gif]
Ill need to invest in a new meter me thinks :'(
oh well keep tryin eh >:( :y
fiend61
  • york
  • each to their own
« Reply #3 on: 16 July 2011, 11:55:03 »
yup new meter would be a good start  :y
