F/L Battery disconnection
Started by Shackeng, 23 July 2011, 14:03:48
Shackeng
Quote.... Although I'm not sure of the easiest way to set off the alarm,  .....
Lock the car via the fob & then unlock with the key in the door, opening the door should then trigger the alarm.  :y
or lock the door with the drivers window open .. then wave an arm in through the open window !!!   :)
Tried that, ........nothing, but rocking it did set off the indicators only. Are there any relays/fuses associated with this system (he says, too lazy to look in the book ::) ::) ::))
Shackeng
The alarm does not sound when I do this, nor do the trafficators flash, although they do if I rock the car when locked. The 30A fuse which supplies this also does other stuff which still work. Is there a common point where both horns may have become disconnected? And is there a relay involved?
