Author Topic: electrical window swaping  (Read 1788 times)
fakeq
    • b x20xev 96 cd st
« on: 01 August 2011, 16:22:10 »
Hi
Im changing the wireing from front left door atm. and cant find a safe way to get the plastic circle thingy off the the door. wery hard to see how this is secured. nothing in haynes describeing it eather.
Re: electrical window swaping
« Reply #1 on: 01 August 2011, 16:27:25 »
Pair of grips and twist
fakeq
    • b x20xev 96 cd st
« Reply #2 on: 01 August 2011, 16:31:01 »
ah I see, on both sides or only from inside and then pull out from the outside?
« Reply #3 on: 01 August 2011, 16:33:29 »
Open door and grip the circular plug on the outside (above check strap) then twist downwards
fakeq
    • b x20xev 96 cd st
« Reply #4 on: 01 August 2011, 16:46:35 »
ok, so I need to put the quick connector back so I get bether grip? so hard to get good grip eather way, wery thight space inside to work on.
« Reply #5 on: 01 August 2011, 16:51:09 »
Have you managed to separate the circular connector, if so, just a case of removing old door loom, route new loom and push the circular connector from inside the door towards the outside and re-connect
fakeq
    • b x20xev 96 cd st
« Reply #6 on: 01 August 2011, 17:16:14 »
Thanks alott!
Was a fiddle but alitlebit force and it camed out :)
« Reply #7 on: 01 August 2011, 17:23:24 »
Thanks alott!
Persistence pays off. Well done :y
