Author Topic: CCRT 2008  (Read 2455 times)
Adies08
  • ipswich
    • 2000 omega cdx
CCRT 2008
« on: 02 August 2011, 19:51:41 »
Hi does anyone know anything about the CCRT2008 radio. It says in the manual to use the phone in it you need a registered sim card with your customer id on ???? Where would i get one of these ?? Cheers
« Last Edit: 02 August 2011, 19:52:10 by Adies08 »
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: CCRT 2008
« Reply #1 on: 03 August 2011, 00:11:51 »
basically if it is the same as a ccrt 700 all you need is an o2 or vodaphone pay as you go sim then away you go  :y
Adies08
  • ipswich
    • 2000 omega cdx
Re: CCRT 2008
« Reply #2 on: 03 August 2011, 07:50:45 »
ok cheers mate. If my omega was fitted with a ccr 2006 will it have all the relevant parts to run the ccrt 2008 ?
Re: CCRT 2008
« Reply #3 on: 03 August 2011, 10:25:40 »
Nope. Need a CCRT MID and wiring mods to the loom, so would be easier to source a TM 36 way ISO connector to modify
twiglet
  • Norwich, Norfolk
Re: CCRT 2008
« Reply #4 on: 03 August 2011, 12:36:48 »
So you might as well go the whole hog and fit a NCDC2015 with Telematics and CID  :y
« Last Edit: 03 August 2011, 12:37:13 by jamestayloruk »
Re: CCRT 2008
« Reply #5 on: 04 August 2011, 10:14:51 »
Easy enough conversion, but you need wiring diagrams for both ;)
Ccrt2008 is similar to ccrt700 in prefacelifts, though only 4 disc changer
Page created in 0.099 seconds with 21 queries.
