Author Topic: SOMEONE IS PULLING THE OMEGA BACKWARDS  (Read 5970 times)
VOYAGER
  • ANKARA/TURKEY
    • 1998 Omega CD V6 AUTO
« on: 01 July 2011, 08:32:32 »
Hello,
When I attempt to move the car in "D" position and I depress the accelerator even all the way down, my Omega does not move normally. She moves very slowly for the first one hundred meters and I feel like someone is holding the car or pulling backwards within this period :-/. At around one hundred meters, everything turns back to normal and she accelerates as expected.
On the even surface, no problem but, uphill position creates problems  :-[since it happens no matter what the engine is cold or hot.
By the way, even if the accelerator is fully depressed, no RPM rises and it stays between idle and 1000 RPM range.
It happens when in gas or LPG mode.
Any ideas would be greatly appreciated.
« Last Edit: 01 July 2011, 12:50:43 by VOYAGER1 »
Re: SOMEONE IS PULLING THE OMEGA BACKWARDS
« Reply #1 on: 01 July 2011, 08:51:32 »
Check ATF level first mate, and top up if low as the howto  :y
VOYAGER
  • ANKARA/TURKEY
« Reply #2 on: 01 July 2011, 09:28:15 »
Thanks for the comment mate.
With the same opinion, I have it checked almost every month at my friend's service facility, so level is normal and no leaks...
« Last Edit: 01 July 2011, 12:51:45 by VOYAGER1 »
« Reply #3 on: 01 July 2011, 13:39:11 »
did you try 1,2,3 mode ?
VOYAGER
  • ANKARA/TURKEY
« Reply #4 on: 01 July 2011, 15:16:49 »
No, I did not.
But, while it is returning to normal, she changes the shift smoothly like nothing has happened. :-?
For those reasons above, I think there might be something wrong in multiram or anywhere else but not in the automatic gearbox. Or, in LPG system since both ECUs are working together.
After a filter change and a program update on the LPG system may indicate something... :-/
Those are my opinions at a first glance.
I'd better see the technician's comments to the topic for a while...
« Last Edit: 01 July 2011, 15:18:10 by VOYAGER1 »
« Reply #5 on: 01 July 2011, 18:52:12 »
I dont think this problem related to multi-rams..
do you see any fault message about autobox ?
check tps imo :-/
VOYAGER
  • ANKARA/TURKEY
« Reply #6 on: 01 July 2011, 21:35:52 »
No fault message and no evidence related with the auto box.
« Reply #7 on: 01 July 2011, 23:20:55 »
you have pm :y
Rich-K
  • West Yorkshire
« Reply #8 on: 15 July 2011, 14:21:12 »
Sounds like you might be driving with the hand brake on!!!!!!
« Reply #9 on: 15 July 2011, 14:25:00 »
Any stored engine codes  :-/
VOYAGER
  • ANKARA/TURKEY
« Reply #10 on: 18 July 2011, 19:03:58 »
No, no codes related with either autobox or engine.
« Reply #11 on: 19 July 2011, 09:46:05 »
What about ABS / TC?
I saw a car ages ago which had similar symptoms. Would drive quite normally if you pulled the ABS/TC fuse out. If you didn't, it seemed to be in permanent traction control and just wouldn't accelerate from rest.
This was an ex-plod, and the ABS sensor wiring had been hacked about. Might be worth a check, though.
car-nut
  • Kent Border, East Sussex
  • Me & My Motors are Truly 1 off's
    • Custom Mondeo TDCi Estate
« Reply #12 on: 24 July 2011, 16:34:57 »
Could the gear selector switch just need a clean?
old git
  • Shrewsbury
« Reply #13 on: 26 July 2011, 19:33:07 »
just a thought(probably a naff one)could it be related to the snow button that would give a slow start up to about 30 ish and then work normaly
« Reply #14 on: 27 July 2011, 10:24:09 »
a talk to a mechanic reminded me to check your lambda sensors.. if they are never changed , you are likely to use them more than their service life ..
« Last Edit: 27 July 2011, 12:18:30 by cem_devecioglu »
