Author Topic: CCR2006 CD/CASS/RADIO  (Read 2296 times)
plumbob
  • enfield
    • omega 2.2
« on: 11 August 2011, 12:38:02 »
Hi all thanks for suggestions from previous posting,but could somone please tell me if this unit is a straight swop for a 2005?. I've noticed some suggesting it is,but I'm not getting any display from the radio,i turn it on with AS pressed in and hear the beep but no display.Are the display connections the same?Haynes manual shows the same connections?help!!!
Re: CCR2006 CD/CASS/RADIO
« Reply #1 on: 11 August 2011, 12:48:01 »
Straight swap. No lights on radio or nothing showing on the MID :question
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 11 August 2011, 16:36:11 »
Straight swap -
Did the display work correctly on the previous radio?
Check all plugs are firmly in place
Radio & Decoding Technician
www.dndservices.co.uk
plumbob
  • enfield
    • omega 2.2
« Reply #3 on: 11 August 2011, 17:42:06 »
hi thanks for replys,yes display was fine on the old radio. The lights come on when i turn it on,the time/date goes and nothing?
« Reply #4 on: 11 August 2011, 17:50:37 »
Are the multi-plugs still held firm in the rear of the cage
plumbob
  • enfield
    • omega 2.2
« Reply #5 on: 11 August 2011, 18:56:32 »
Hi Robg I hav'nt had time to check yet got to get 3yr old to bed i'm going to have a look in about 1/2 hour cheers
plumbob
  • enfield
    • omega 2.2
« Reply #6 on: 11 August 2011, 20:16:46 »
hi Robg spot on,the top multi plug had a clip holding it in broken so was only half connecting,pushed it in and off we went.Thanks a lot cheers.
« Reply #7 on: 11 August 2011, 20:26:46 »
Easy fix then :y
