Author Topic: TC kontrol modul  (Read 2730 times)
kvcali
  • Kraljevo, Serbia
    • omega 2.0 facelift 2000.
TC kontrol modul
« on: 14 August 2011, 13:50:13 »
Regards from Serbia
 sorry for bad english:)
 I have a question for you where the units of TC electronic traction control system
accurate location of the module on the car omega b '96. 2.5V6
thanks
  • Auckland
    • Mazda MPV
Re: TC kontrol modul
« Reply #1 on: 14 August 2011, 15:28:12 »
Just about visible in this photo.
(it is the shiney metal block in the centre of the photo with lots of hydraulic brake pipes going to it)
« Last Edit: 14 August 2011, 15:30:10 by andyh »
« Reply #2 on: 14 August 2011, 15:31:08 »
right hand side of the engine,  ...
You mean the left hand side. All left or right is when you're sat in the car.
And this assumes it's the same side of the car as our right hand drive cars.  :-/ :-/
kvcali
  • Kraljevo, Serbia
« Reply #3 on: 14 August 2011, 16:52:20 »
Thanks guys
I am interested only electronic units for TC, location, and not the ABS hydraulic block :y
« Reply #4 on: 14 August 2011, 16:57:27 »
The electronics for TC are part of the ABS ECU, which is attached to the ABS unit.
« Reply #5 on: 14 August 2011, 17:05:50 »
Thanks guys
As TB says its all one unit, and difficult to replace! (access is problem)
What are you issues? Speedometer not working? ABS light on? Might be worth cleaning the sensors to start with, then go from there. Its a lot easier  :y
« Reply #6 on: 14 August 2011, 17:08:34 »
LHD will have it the other side I suspect.  Pre 1998 ABS/TC ECUs are very reliable, although the TC function isn't as good as later ones.
kvcali
  • Kraljevo, Serbia
« Reply #7 on: 14 August 2011, 17:26:32 »
I really wanted the TC omega installed in calibra, but not how I see the same system as in Cali V6 where the ecu for the abs and tc separated
I have yet to take off with cali V6   :question :'(
« Reply #8 on: 14 August 2011, 17:29:41 »
Not sure thats going to be interchangeable! Calibra is FWD for starters  :-/
kvcali
  • Kraljevo, Serbia
« Reply #9 on: 14 August 2011, 17:36:20 »
I know about it because I will still take off with the Cali V6 but thanks for the answers
