Author Topic: Very poor cold starting - fuse + relay info please  (Read 6871 times)
Vulpine
  • Kent UK
  • Omega 2.5TD The Vegmega!!
    • Omega 2.5TD '97
Re: Very poor cold starting - fuse + relay info please
« Reply #15 on: 15 August 2011, 15:55:04 »
indeed, but all sub 30mph 1.6miles to work for today and tomorrow only.
maybe if weather is ok, i'll get the push bike out even to be on the safe side!!
« Last Edit: 15 August 2011, 16:46:31 by vulpine »
Admin edit
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #16 on: 21 May 2012, 19:45:44 »
Hi All
Car still going well but need to know which relay is the Fuel Lift Pump Relay. Can anyone tell me which one it is?
Want to bridge the relay so the lift pump is always on (with engine) and/or a switch on the dash.
Thanks
Admin edit
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #17 on: 21 May 2012, 21:36:03 »
HI
Ah sorted! If I only read things properly first time! Using the H@ynes and info on here, for the 2.5td:
With reference to:
Code: [Select]
Pos Code Colour Option Function
1 - Violet Test Connector
K96 Grey Cooling Fan
2 K97 Black Headlamp Washers
3 K22 White AC Coolant Pump
4 K8 Yellow Wipers (int)
5 K127 Green Without Aircon Charge Cooler
K60 Green With Aircon Aircon Compressor
6 K26 Grey Without Aircon Blower
K87 Green With Aircon Aux cooling Fan
7 K67 Green Without Aircon Cooling Fan
K51 Black With Aircon Cooling Fan
8 K48 Orange Aircon only Blower
8a F50 Red ?? ??
9 K80 Green Fuel Filter heater
10 K16 Black Lift Pump (in fuel tank)
12a F39 Green Headlamp Washers
17 K52 Brown Blower
18a F42 Black ?? ??
F50 Blue ?? ??
18b F52 Black Without Aircon ??
19a F36 Green ?? ??
20 K13 Green Park/Neutral (AT)
27a F55 Yellow ?? ??
28a F42 Black ?? ??
28b F52 Black ?? ??
30 K25 Glow plugs
40 K17 Polarity Protection
Anyone help with filling out the ??s for the fuses?
My interest is item 10, the fuel relay. Time to mod that circuit!
« Last Edit: 21 May 2012, 21:47:12 by Vulpine »
Admin edit
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #18 on: 21 May 2012, 22:03:58 »
Admin edit
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #19 on: 24 May 2012, 09:26:40 »
Well on checking circuits, fuses and using test lamps, 12v is supplied to the pump whenever the vehicle ignition is on.
But i have no flow of fuel when there is :(
I have 12v to the top of the tank connector, so next job is to remove the pump from the tank (again) and see whats up.
anyone got a spare going for sale?
Admin edit
