Author Topic: CCR2006 to NCDC2013 upgrade  (Read 2373 times)
twiglet
  • Norwich, Norfolk
« on: 22 August 2011, 22:55:51 »
This would be in 2002 2.2 CDX. I've got the HU and GID, plus the aerial for the GPS.
Is it then just a case of old HU + screen out, new HU + screen it? Or does the wiring harness have to be changed to suit?
TIA  :y
Re: CCR2006 to NCDC2013 upgrade
« Reply #1 on: 22 August 2011, 22:56:58 »
TIA  :y
PM sent
twiglet
  • Norwich, Norfolk
« Reply #2 on: 22 August 2011, 23:07:34 »
All sorted now, thanks to Rob  :y
    • 530D M Sport, 330i Coupe
« Reply #3 on: 22 August 2011, 23:09:19 »
Ah, a little loom required.....
« Reply #4 on: 23 August 2011, 18:49:43 »
Aye, minor mod to TM loom.
I've kept my loom from Goldie, so I have the details
« Reply #5 on: 25 August 2011, 20:42:36 »
IIRC the minimum you can get away with is Headunit pin 32 to display unit 10 and head unit pin 33 to display unit pin 11.
Obviously you will need to remove the existing pin 10 and 11 connections and tape them out of the way. I think you also have to remove pin 9 as well, though I haven't got my document to hand at the moment.
« Reply #6 on: 25 August 2011, 22:01:43 »
Sounds like I need to remove the trafficmaster loom from bluey the breaker. ::) ;D
« Reply #7 on: 26 August 2011, 09:02:45 »
Albs - thats the CAN I was talking about in PMs :y
Also, on the screen, you need to connect pin 1 to pin 34 if ever you want to run any diagnostics on it.
« Reply #8 on: 26 August 2011, 09:07:01 »
Not confident of doing that tbh, but I think I know a man who is. ;) ::)
« Reply #9 on: 26 August 2011, 13:14:15 »
Sounds like you want a favour then ::) ::) :D :D
« Reply #10 on: 26 August 2011, 22:16:34 »
Possibly. ::) :D..........thing is, my 2013 may well be in full working order now. Swapping the board with TB,s has cured the problem of no sound. :) But without plugging it and its paired screen into a fully Bose enabled setup, I dont know.
Unless of course that gobbledegook Tb was talking a couple of posts previously is a way of avoiding that. :-/
« Last Edit: 26 August 2011, 22:17:48 by albitz »
