Author Topic: Headunit Help Pls  (Read 2349 times)
Daryn
Headunit Help Pls
« on: 27 August 2011, 23:14:37 »
Hi All
Hope you all well i am new on here as i just got my Omega Elite facelift..
the Qs i have is =
I love the Bose setup sounds fab. Anyway my cds will not play.. I load them in and it checks all discs then says error or no cd.. I has played 1 disc which was a cdr i burnt slowly. But now wont play any.. Is it easy to change HU but keep my speakers/amp.. Or any1 know if its possible to replace HU... Found a company in Brighton says they can fix for £150.. Is it worth doing that.. Soz 4 long post.. Hope to hear back...     :y
Re: Headunit Help Pls
« Reply #1 on: 27 August 2011, 23:16:59 »
Laser is donald mate, CDR`s bugger them. You can replace with another OE HU but must be bose
« Reply #2 on: 27 August 2011, 23:19:55 »
Your laser is nackered thats why its not playing CD's.
If you want a replacement head unit that's none Bose you have to rip everything out, amp, all the loom, head unit the works.
Bose are 2 Ohm, everything else is 4 Ohm  :y
twiglet
  • Norwich, Norfolk
« Reply #3 on: 27 August 2011, 23:39:53 »
What model is you current headunit? I might be able to help you out.  :y
Daryn
« Reply #4 on: 27 August 2011, 23:40:28 »
Thanks all
When i got the car there was a pre recorded cd left in glove box 1 not a copy and that didnt work maybe prevous owner tryed cdr's...
Any1 know if its hard to get another unit the same 1 crc 600... i know of som1 selling the next model up the phone 1 i dont want to use phone sure thats Bose too would it work in mine he has the screen also..  :y
twiglet
  • Norwich, Norfolk
« Reply #5 on: 27 August 2011, 23:48:07 »
I assume you have a CCR2006 then?
A nice upgrade would be to go to a NCDC2013. This will give you built in satnav, as well as 4 disc cd changer, and will work with your steering wheel controls and Bose. There is mimimal modifications required to the standard wiring harness for this upgrade.
I have one of these units available if you are interested.  :y
Daryn
« Reply #6 on: 27 August 2011, 23:51:51 »
I am intrested thank you.. Do i need to use sat nav as i have already on my phone.. Is it plug n play or what would i have to do.. Sounds good tho..  8-)
twiglet
  • Norwich, Norfolk
« Reply #7 on: 28 August 2011, 00:00:36 »
Where about's are you mate?
You don't have to use the sat nav, but it's a nice function to have built into the car. The headunit itself will plug in and work, but the wiring modifications will be for the replacement screen to work fully. (the screen will be supplied with the headunit).  :y
Daryn
« Reply #8 on: 28 August 2011, 00:07:06 »
Im in West London.. So i guess u know how to install it too? How much you looking for 4 it also fitting lol
twiglet
  • Norwich, Norfolk
« Reply #9 on: 28 August 2011, 00:27:50 »
PM sent  :y
Daryn
« Reply #10 on: 28 August 2011, 00:42:23 »
Sent pm
