Author Topic: windscreen washers not working  (Read 1764 times)
Zpower
« on: 08 September 2011, 18:56:27 »
Hi The windscreen washers are not working,pump not running,not sure to start at the pump looking for power or the switch? The fuse looks ok,have they a common fault?
Cheers Dave
Re: windscreen washers not working
« Reply #1 on: 08 September 2011, 19:12:22 »
If fuse is OK, unplug pump connector and stick 12v on it
« Reply #2 on: 08 September 2011, 19:36:42 »
As Rob said ^^^^  - first check you have 12v at the pump connector!
Pumps cheap enough off ebay  :y
