Author Topic: codes  (Read 2606 times)
Bob G
  • Gloucester
codes
« on: 08 September 2011, 15:45:37 »
Just to confirm that for a radio decode it needs to be obtained from dealer.
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: codes
« Reply #1 on: 08 September 2011, 16:06:06 »
or you could send a pm to dave dnd services - he is a member on here
Bob G
  • Gloucester
Re: codes
« Reply #2 on: 08 September 2011, 16:18:19 »
Ok thanks for that, already spoke but when I go back wil tell him i am from this site.
Re: codes
« Reply #3 on: 08 September 2011, 16:20:01 »
The original radio code can be obtained from Vauxhall, which of course would be of no use to you if the radio has been changed at some time. DaveDND will be able to to sort you out for a code for your current radio.
The advantage of the Car Pass from Vauxhall is that you also get the key & immobiliser code for your car ........ again assuming that nobody has been there before you.  ;)
Bob G
  • Gloucester
Re: codes
« Reply #4 on: 08 September 2011, 17:00:55 »
Have the key pass but as the radio that was in the car was code cancelled mode not needed, have been given a new radio as a sort of upgrade but no code, not fitted it yet but can always hope that it is code locked but chance of 2 are faint.
Vauxhall code fee is £30 +vat here in Glos
Re: codes
« Reply #5 on: 08 September 2011, 19:56:46 »
If its not original radio, no point going to dealer.
Try Dave DND on this site :y
Re: codes
« Reply #6 on: 09 September 2011, 04:04:13 »
£25.00 in Darlington, took not time and had a free coffee whilst I waited..... :y :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: codes
« Reply #7 on: 09 September 2011, 17:27:37 »
Model number of radio not given, so can only suggest to look here for a solution
http://www.dndservices.co.uk/manufacturers_d.php?manufacturerid=39&mmode=decode
Radio & Decoding Technician
Bob G
  • Gloucester
Re: codes
« Reply #8 on: 09 September 2011, 18:08:57 »
Dave it is a Phillips 2006
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: codes
« Reply #9 on: 10 September 2011, 17:31:01 »
Bob G
  • Gloucester
Re: codes
« Reply #10 on: 10 September 2011, 17:36:00 »
Thanks dave will send it asp
Bob G
  • Gloucester
Re: codes
« Reply #11 on: 12 September 2011, 12:02:14 »
Dealer quite happy to do code even if it is not orginal radio, they said that as people change radios all the time it would be a poor service if they could not get codes, all they need is the serial number and your money.
