Pages: 1 2 [3]  All   Go Down
Author Topic: stereo removal tool.  (Read 8190 times)
Re: stereo removal tool.
« Reply #30 on: 12 September 2011, 21:23:11 »
Webby, if you fancy a run, I will willing attempt to get it out using my (modified) shitty Autoleads junk.
You know Mrs TB's crochet needles are the answer!
I'm guessing you've seen me do that ::)
Mind you, was it your one that was stuck absolutely solid? Another 10minute job taking 4 hours ;D
Yes, Mrs VXL V6's Estate, Which went from a CDR2005 to a 2013, GID and Bose... was all going exceptionally well until a minor wiring issue caused Tech II not to communicate to program the screen followed by me removing more of the bezel than the HU, followed by the connector block bending, followed by buttons not working on the replacement bezel... Oh Joy!
Indeed, try as I might, I have been unable to erase that saga from my memory ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #31 on: 13 September 2011, 09:57:05 »
mine's a cdr 2005 :) hopefully that will come out easy. touch wood  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #32 on: 13 September 2011, 18:19:56 »
hi again guys. sorry for loads of posts  ::)
however here's the link to the replacing the air con panel that jay w has kindly provided...
http://www.omegaowners.com/forum/YaBB.pl?num=1152745540
i note that this is to take the whole unit out but is all this necesary to replace the heater/aircon panel?
RIP Paul Lovejoy
« Reply #33 on: 13 September 2011, 18:20:19 »
Accelerate hard and those cdr2005s fall out ;D
//Edit: Just seen its 'only' a 2.5 :P
« Last Edit: 13 September 2011, 18:20:55 by TheBoy »
Webby the Bear
  • Northampton
« Reply #34 on: 13 September 2011, 18:24:46 »
well dlk had trouble getting it out!!!  :-X :-X :-X ;D ;D ;D ;D
RIP Paul Lovejoy
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #35 on: 13 September 2011, 23:39:24 »
had trouble getting what out :D :D :D :-X
other rides
Webby the Bear
  • Northampton
« Reply #36 on: 13 September 2011, 23:53:43 »
his tool.  :D :D :D
oooh errr i mean his radio removal tool  :-[ :-X :-X :-X :-X ;D ;D ;D
RIP Paul Lovejoy
Pages: 1 2 [3]  All   Go Up
