Author Topic: Does CCr 600 have "aux in" connector.  (Read 4441 times)
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« on: 16 July 2011, 22:25:30 »
Hiya fellas, as per title really. Due to my CD changer being "Donald" and the car only being used for towing caravan holiday duties, was wondering if the CCR600 has an "aux in" socket (no Audio handbook). The thought being that i can use the "line out" from a portable CD player instead of one of those "CD/cassette converter" jobs. If someone can advise which cable to buy, or has one for sale then that would stop me buying a cassette jobbie.
Any advice much appreciated :y
Those are my principles, if you don't like them I have others.
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Re: Does CCr 600 have "aux in" connector.
« Reply #1 on: 17 July 2011, 00:03:34 »
No, it doesn't have, but you can make it, if you are a bit of "electric" and have an hour of free time...I did it and it's playing nice.
danzigfan
« Reply #2 on: 17 July 2011, 00:05:41 »
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #3 on: 17 July 2011, 09:07:23 »
Hiya fella, cheers for that. Would you happen to know the pins/connectors you wired the lead to? Thanks :y
danzigfan
« Reply #4 on: 17 July 2011, 09:50:03 »
If you still have your radio code it won't be a problem. You neee to take radio out and disassemble covers. If you have will to do that I can post you pictures of what more you have to do. And you need "female aux"
danzigfan
« Reply #5 on: 17 July 2011, 09:51:40 »
Sorry, female 3,5mm jack input
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 17 July 2011, 15:12:56 »
Its worth bearing in mind that this modification does nothing to match the impedances or levels of any signals, and has the potential to seriously damage both the head unit and the aux device.
Whilst it may work for an electronics engineer who is mindfull of the limitations, I certainly would not recommend it to anyone else.
 :-X
Radio & Decoding Technician
www.dndservices.co.uk
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #7 on: 17 July 2011, 15:58:55 »
I appreciate what you're saying Dave. Having seen the "remove case" part I've decided to go with the "CD/cassette" adapter option..... may get a bit of "hiss" which could be factored out, but at the end of the day, the car is only going to be used for holidays so playing safe. All my 4 & 6 yr old want is music ;D Thanks for the concern & heads up.  Cheers fella:y
P.s I'm an apprentice trained HNC electronis guy doing BMS systems for last 20yrs....but can't be arsed!!
thewww
« Reply #8 on: 22 September 2011, 20:19:13 »
How do you select the audio input with this mod?  could you post a picture or diagram of what pins to connect to please.
thanks
danzigfan
« Reply #9 on: 22 September 2011, 20:56:16 »
I"ll put some pics of  it on, but not before tomorow. If you're a bit into electric you"ll see it"s very simple and it still works nice on mine. Only catch is you need a blank cassette inside to make radio think it's cassette playing. Press button for radio/cdc/cassette - last one is aux. In meantime please go to newbie area and introduce yourself to the others, they will apriciate it :y
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #10 on: 29 September 2011, 00:23:40 »
Easier way - Get one of these from somewhere
http://www.ebay.co.uk/itm/CASSETTE-ADAPTER-CAR-KIT-IPOD-MP3-MP4-MD-CD-PLAYER-/150668554842?pt=UK_AudioVideoElectronics_PortableAudio_MP3PlayerCarKits&hash=item23148bb25a
I got one from comet and it works really well if you dont over drive it (input volume)
I even connect my phone and use it as handfree
danzigfan
« Reply #11 on: 29 September 2011, 07:20:37 »
I started with this cass/mp3 modulator too but was distracted by cassette noise (not a quality I wanted) so I disassembled h/u and soldered wiring directly into circuit, right after the cassette signal amp to avoid distortion, fitted aux input into the dash and that's it. No murmur behind the music, maybe not the simpliest way but one of the cheapest way to upgrade h/u and preserve classic look of the interiorerior
Page created in 0.354 seconds with 20 queries.
