Author Topic: Discovery TDi + Cambelt change question...  (Read 3405 times)
Taxi_Driver
Re: Discovery TDi + Cambelt change question...
« Reply #15 on: 03 March 2008, 19:22:09 »
My brother is on his 3rd Disco......
Each one has managed to land him a BIG garage bill.......
Including failed turbo/autobox.
I think his first one a 3.5V8 was the worst, spent most of its time on the back of a low loader  :o
the other two he's had were/are TD's
Not our favourite BMW unit per chance!
More than likely as they are 2.5's 6cyl, tho never had the inclination to pop the bonnet on them to take a butchers  ;D
He does drive them quite hard......i always find it quite amusing when he pulls away.........lots of diesel grunt noise going on.......but not much movement  ;D Probably he's got used to flooring them on take off to get them to move  ;D ::)
Martin_1962
« Reply #16 on: 03 March 2008, 21:04:52 »
Started with TDI300 direct injection 4 cylinder descended from the older Diesel one.
Later ones had a 5 cylinder Storm the TD5 I Think it is related to the 4 cylinder TD in the MOntego Maestro
motmann
  • birmingham
« Reply #17 on: 03 March 2008, 23:22:56 »
older tdi cambelt not to bad to change, waterpump and front cover off plus fan and cowl, genuine parts a bit pricey just done one in the workshop. on the 4x4 note i have just got a cheap swb mitsubishi shogun 2.5td, what a great old truck, drives like a car and not bad on diesel either! :y
« Reply #18 on: 03 March 2008, 23:51:16 »
Hi,
You mean Tdis, no TD models were made for discoverys
Cheers,
Iain
Do you know of a Diesel engine that is not injected then? :)
Martin_1962
« Reply #19 on: 04 March 2008, 08:23:31 »
Hi,
Cheers,
Iain
The LR had an indirect injection lump, the TDI300 was a direct injection version
Arrolman
  • Renfrew,Scotland
« Reply #20 on: 04 March 2008, 17:41:32 »
2.5 N/A unit and the 2.5TD unit used in the 90/110 don't have injection ;)
Looking to win the lottery..........
Martin_1962
« Reply #21 on: 04 March 2008, 20:02:07 »
All Diesels are injection, the older indirect engine had swirl chambers which could fall out, the DIscovery had a direct injection turbo version
I have seen inside one - a cousin owns a 88 Diesel refitted with a  Montego engine, a TD300 Discovery and a 109 Christmas tree with Salisbury axles
« Last Edit: 04 March 2008, 20:04:21 by Martin_1962 »
Page created in 0.029 seconds with 20 queries.
