Author Topic: Golf GTI - grinding noise  (Read 5419 times)
symes
  • oxford
    • R reg 940 volvo
Re: Golf GTI - grinding noise
« Reply #15 on: 26 September 2011, 20:41:40 »
When you jacked it up and turned wheel did you hold drive shaft? if wheel moved and shaft was still(slack) then thats ya problem - drive shaft.
« Reply #16 on: 26 September 2011, 21:22:43 »
No I didn't hold it, but I could see that the driveshaft wasn't moving when the wheel was! and when I checked the drivers side there was play there as well. I waggled the wheel with my foot and stuck my head near the gearbox.  The clacking sound seemed to come from where the driveshaft goes into the gearbox....
If that makes sense?  ::)
I'll check again tomorrow, and will hold my shaft while waggling!!  :D  Cheers Symes  :y
« Reply #17 on: 05 October 2011, 19:06:31 »
It turned out that 'The noise' was caused by a sheared gearbox mounting bolt, so there was some serious vibrations when driven hard!!!  :y
« Reply #18 on: 05 October 2011, 19:43:53 »
That sounds like a result, to me! Cheaper than a new gearbox/driveshaft/clutch/etc ;)
« Reply #19 on: 05 October 2011, 21:06:40 »
Which is no real surprise really... Sounds like it's been thrashed to within an inch of its life though :( :(
« Reply #20 on: 05 October 2011, 21:23:11 »
Yes definately a result!!  :)  and yes It's probably been well thrashed!!  :o  Stupid car to buy at the auctions really, but I had a WTF moment!  ::)
The good news is that I will at least break even on this one and hopefully might make a small profit!!  :y
