Author Topic: Car wont turn over  (Read 2926 times)
marco24v
  • Middlesbrough
    • Lancer
Car wont turn over
« on: 25 September 2011, 19:42:54 »
Hi guys. I've just bought my first miggy today and a good one.  The trouble is i've been cleaning it all day and when i've been to start it all the lights come on but it just wont start.  Is it simply the battery is flat or could their be more to the problem?  Its been sat for a month and it appears to be the original battery on the car from new because their is no sign of a change in the service history.  Would appreciate your replies etc
thanks Marc
marco24v
  • Middlesbrough
    • Lancer
Re: Car wont turn over
« Reply #1 on: 25 September 2011, 19:45:11 »
forgot to add the is says 'safe' on the trip computer. im assuming this is to do with cd player as it wont work when this is on
« Reply #2 on: 25 September 2011, 21:08:16 »
If you look in the Maintenence Guides section, there is a post by Kevin Wood about checking alternator and battery. Its worth reading through that :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 25 September 2011, 21:13:15 »
sounds like you flattened the battery with the doors being open tbh.
marco24v
  • Middlesbrough
    • Lancer
« Reply #4 on: 25 September 2011, 21:13:39 »
Thank you very much.
« Reply #5 on: 25 September 2011, 21:13:59 »
thanks Marc
get a jump start or charge your battery. If it's been sat a month the battery will probably have been a little flat anyway, and cleaning it all day you'll have had a door or 3 open for long periods with the courtesy lights on. Charge the battery or get it started & go from there.  :y
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #6 on: 25 September 2011, 22:27:25 »
and hopefully you have the radio code aswell  ;)
marco24v
  • Middlesbrough
    • Lancer
« Reply #7 on: 26 September 2011, 08:46:26 »
[/quote]
Good point.  It looks like I may have dont that.  It was filthy but have managed to make it pristine.  I think its the original battery so could be due a new one.  No sign of a bill for one but i'll see if it works again.
marco24v
  • Middlesbrough
    • Lancer
« Reply #8 on: 26 September 2011, 08:47:57 »
[/quote]
Yes I have the radio code.  How do you reset it when it says safe? Is their something you press first?
tony2
  • peterlee north east
    • 2.6 cdx auto
« Reply #9 on: 26 September 2011, 09:29:13 »
hi marco  go to maintanance section scrol down to audio section all you need their to reset code on radio tony :y
tony2
    • 2.6 cdx auto
« Reply #10 on: 26 September 2011, 09:32:55 »
hi mark forgot to tell you  when you go to maint section go to maint guide index then scrol down to audio :y
marco24v
  • Middlesbrough
    • Lancer
« Reply #11 on: 26 September 2011, 10:22:26 »
Thanks very much. Will give it a try later and see how it goes.
