Author Topic: Vaccum Hose - Fuel Pressure Regulator  (Read 1307 times)
nordic
  • Sunderland
« on: 27 September 2011, 15:57:04 »
Hi,
Having just replaced the thermostat and cam cover gaskets on my 2001 3.0 V6 I am busy reassembling.
Is the vaccum hose that connects to the fuel pressure regulator a rubber u - shape connection which leads towards the front of the car?
Sadly, I just can't remember as I am having to do the job when time allows and memory fades!
Many thanks,
Andy :-\
Re: Vaccum Hose - Fuel Pressure Regulator
« Reply #1 on: 27 September 2011, 16:08:43 »
The hose with the U shaped rubber section is the vacuum supply for the rear multiram actuator.
The fuel pressure regulator reference port connects to a rubber hose which extends backwards from the hose which feeds the idle air valve on the non-DBW V6s. :y
nordic
  • Sunderland
« Reply #2 on: 27 September 2011, 16:34:15 »
So this u-shaped rubber connects to the rear multi-ram on the plenulum and runs a vaccum pipe from it towards the front of the car?
If that is so - I can't locate anything that would attach to the fuel pressure regulator?
Does anyone have any photo's which may help?
Many thanks - it has got me thinking..
Andy
« Reply #3 on: 27 September 2011, 16:45:30 »
If you look at the idle control vale that fits into the right hand side of the plenum at the front you will see it connects to the inlet trumpet via a rubber pipe. T'd off this pipe is a smaller bore rubber pipe that runs to the rear of the engine, it is this pipe that attaches to the fuel pressure regulator.
nordic
  • Sunderland
« Reply #4 on: 27 September 2011, 16:59:47 »
FANTASTIC !!!!
I had pushed this hose down next to the radiator out of the way. My numbering system confirms you are spot on!
I feel like a fool but you guys have saved the day - even if it has cost me my pride! :D
Many thanks to all for helping :y
Andy
