Author Topic: Removing steering idler  (Read 3378 times)
Martin_1962
Re: Removing steering idler
« Reply #15 on: 01 October 2011, 18:05:12 »
20 minutes of hammering and it popped off.
TRE popped out OK so centre tie rod OK.
HOWEVER
The inner core of the old idler is rusted to the pivot, 1/3rd of the way cutting the bush off the pivot.
Should I grease it before fitting the new one?
Finished about 17:00 and still a couple of hours work to go.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #16 on: 01 October 2011, 19:13:48 »
I did on mine. dont do no harm.
Solar charger fitted.
If not Broke dont fix it..
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
« Reply #17 on: 01 October 2011, 20:59:20 »
2 hammer worked for me, just have to keep smacking till it comes off!
Martin_1962
« Reply #18 on: 01 October 2011, 21:07:52 »
Tomorrow I'll be firing up the compressor and the cutting disc and finishing off the idler mount strip, then fit the idler.
I will then lock the steering in position and measure the disc position to the wing. Then do the track rod.
Martin_1962
« Reply #19 on: 02 October 2011, 12:37:14 »
All done and now OK, did tracking by measuring before and after
« Reply #20 on: 02 October 2011, 18:46:42 »
At Newent I tried for 30 minutes with 2 hammers ... got nowhere .... the "experts" turned up .. Daz/Mark DTM/TheBoy  told me I needed bigger hammers so I went to the van to fetch a lump hammer... came back and the thing was already off !!! Obviously a "knack" I don't have .. :)
« Reply #21 on: 02 October 2011, 18:52:56 »
There is the beginnings of a guide in test zone for setting toe, if that helps further. Measuring thread length can still give massive errors.
« Reply #22 on: 02 October 2011, 19:29:06 »
It fell off with the standard 2 hammer trick. Landed on my bloody foot as well ;D
Martin_1962
« Reply #23 on: 02 October 2011, 19:40:43 »
Piece of wood against disc before and after, less than 0.5mm difference
