Author Topic: Romano RIS Software / Diagnostics  (Read 7253 times)
« on: 02 October 2011, 15:34:16 »
I'm currently looking at a 3.0 Elite with a Romano system fitted, that has stopped working following a service.
The "G" light on the changeover switch is flashing very slowly indeed, and it won't flick onto gas.
Looking in the engine bay, the temp sensor to the reducer was in a bad way and I think this is at least, contributing.
Problem is - how do I connect to run diagnostics on this system? I really need to see the values it's getting before I can get any further.
I cannot seem to find any software available anywhere?
Assuming it's legal to do so, does anyone have the romano software that they'd be prepared to lend me? I genuinely don't know the score with this, because my Stag software seems to be free to download - but I can't find the same for Romano?
My stag lead seems to physically fit, but not sure if this could be used to connect with the right software, or if I'd need a different lead?
Any advice or help gratefully received.
Cheers
James
Martin_1962
Re: Romano RIS Software / Diagnostics
« Reply #1 on: 02 October 2011, 17:01:53 »
It was downloadable not sure now - call Mint LPG and ask - they were autogasworldwide
« Reply #2 on: 02 October 2011, 23:06:42 »
What about the lead Martin, do I need a dongle for Romano?
Martin_1962
« Reply #3 on: 02 October 2011, 23:15:28 »
I really don't know cannot get a definate answer off them as someone has made off with my lead
Elitenut
  • Redditch, Worcestershire
« Reply #4 on: 03 October 2011, 09:23:19 »
I have the software installed on my laptop and the connection lead.
Sent PM
Regards
Brian
Martin_1962
« Reply #5 on: 03 October 2011, 10:50:22 »
Sent PM
Regards
Brian
Can you do me a really HUGE favour please?
Can you look at the loom and the lead and get the pins & colour of the wires, mine were chopped off and I need to repair.
Thanks
Martin
Elitenut
« Reply #6 on: 03 October 2011, 15:26:45 »
I haven't got any Romano drawings Martin.
But the Romano uses AEB ecu which is used by several makes of LPG Equipment.
I have PM you some PDF files I've found on the net.
Regards
Brian
Martin_1962
« Reply #7 on: 03 October 2011, 16:53:34 »
Regards
Brian
I assumed you had it on your car! :-[
Elitenut
« Reply #8 on: 03 October 2011, 17:24:43 »
Yes i was on the car when I purchased it.  :( :( :( :(
« Reply #9 on: 03 October 2011, 19:28:41 »
You have PM, Elitenut :)
Thanks again :y
