Pages: 1 [2] 3  All   Go Down
Author Topic: Irmscher body kits! Limited production run.  (Read 7289 times)
Re: Irmscher body kits! Limited production run.
« Reply #15 on: 03 October 2011, 23:47:50 »
I suspect that most of those interested have pikey hooks fitted :-\
Think the single exit bumpers are essentially the same shape as the dual exit ones, only a bit less symetrical :-\
3.2s have twin tailpipes, so should match with the bumpers quite nicely. Single pipe would probably look a bit feeble IMHO.
« Reply #16 on: 04 October 2011, 00:31:09 »
« Reply #17 on: 04 October 2011, 07:50:04 »
Much as I really like the idea of the twin exit exhaust (either side) I can't see an easy solution to the pikey hook issue. I'm sure someone could make a bespoke system that would work, but it won't be easy ::)
« Reply #18 on: 04 October 2011, 18:26:20 »
I don't think the exhausts are part of the plan. But given the number of tow bar configurations, it would have to be a bespoke solution for each car for the one either side exhausts I would have thought. And cutting an Irmscher bumper...ooh that's brave.
Just for info, either side exhaust exit does specify, " not with tow bar"
Believe the conventional exhaust exit bumpers are cheaper are they? and slightly different design?
No shit, sherlock ::)
« Reply #19 on: 04 October 2011, 18:27:20 »
Remove Pikey Bar. Win-win situation for everyone :y
« Reply #20 on: 04 October 2011, 18:38:52 »
Except I need somewhere to mount the LPG filler and I'm not cutting the bumper or the bodywork ;)
Plus, I still have need for it as I sometimes need to tow trailers, as you witnessed a month or so back ;)
« Reply #21 on: 04 October 2011, 18:44:18 »
Do the sensible thing - hide the unsightly filler behind numberplate, and borrow a car from someone when you need a pikey fitting ::)
« Reply #22 on: 04 October 2011, 18:50:08 »
Shall I point out the obvious flaw in that plan? ::) ::)
Number plate on an Estate is on the Tailgate ;D ;D
And borrowing a motor is great if you aren't on a tight time schedule to get to a party :o Oh... And frighteningly, the run down to drop the trailer back I only managed 15 mpg (on the MID) whereas loaded the RR got around 18.5 IIRC :o :o Mind you... I wasn't hanging about :-X :-X :-[ :-[
« Reply #23 on: 04 October 2011, 18:54:17 »
Unless, my dear Watson, you have a pre made, Blue Peter style, one I made earlier, template. Ie, your original pre cut bumper, that fits inside the Irmscher one. ;D
But filler in bumper wont work on Estate.
« Reply #24 on: 04 October 2011, 19:08:48 »
1) Get a proper Omega - a Saloon (prefacelift, obviously)
2) Next time someone asks you to tow something, remember 2 simple words....   ....blank off ::)
« Reply #25 on: 04 October 2011, 19:10:35 »
We can chat over a curry one day, I'll try to explain difficulties with that. Potential difficulties that is.
Martin_1962
« Reply #26 on: 05 October 2011, 15:48:03 »
Don't upset Tunnies Towing Services ;D ;D ;D ;D
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #27 on: 07 October 2011, 21:11:14 »
I still can't see how they do the twin exit system, as when i look under mine the tank is offset closer to the O/S thus not allowing space for a silencer like on the N/S  ???
« Reply #28 on: 07 October 2011, 21:15:19 »
Iirc, its effectively a dummy.A pipe runs across behind the bumper (after the silencer) to the other side,so the gasses come out of two pipes.
« Reply #29 on: 07 October 2011, 21:18:30 »
Just after both pipes come out of the back box the one nearest the o/s turns 90 degrees towards the o/s,runs for about 3 feet and then turns 90 degrees again towards the rear of the car and then comes out from underneath the o/s of the bumper.
Not sure if thats more, or less confusing than the previous post. :D
Pages: 1 [2] 3  All   Go Up
