Author Topic: electronic cigs  (Read 10050 times)
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: electronic cigs
« Reply #15 on: 04 October 2011, 14:29:04 »
Zyban makes people jump of bridges & buildings and no the FDA tested 100 different e-cigs and theyre all bad they all have rat Poisson in them as its used to make the vaporiser work part of the chemical reaction!
all the FDA said about the cheaper ones that they're made in dirty environments and use leaking batteries good eh?
and at the end of the day they give you a cold and with me start you off on a coughing  fit which is only a bad thing!  supprisingloy theres research showing cannabis stops the brain craving nicotine mad eh!
Re: electronic cigs
« Reply #16 on: 04 October 2011, 14:57:00 »
You must have read a different report to the one I did then.
The FDA had approved them for use, although controlled like real cigs, so can't be that bad ::)
Taxi_Driver
Re: electronic cigs
« Reply #17 on: 04 October 2011, 18:16:15 »
My GP's surgery actually supports their use, if it helps you give up real ciggies, altho as there not NHS approved, cannot supply them on prescription   ;)
hercules
  • sunnyudders
Re: electronic cigs
« Reply #18 on: 04 October 2011, 19:38:20 »
so far ive only used it like say that new spray,if i want a fag ive just had 2 pulls on it and it takes away the craving brilliantly.i couldnt smoke it like a fag it tastes like shiite but if it helps me cut down to a stop on the birth of my 4th and final child due on nov 4th.i want to stand in my garden with a large scotch and a cigar and then hopefully call it a do
