Author Topic: Alternator fix - a success story thanks to OOF  (Read 2026 times)
kevinminton
« on: 04 October 2011, 13:57:15 »
Thanks to OOF I was able to change dodgy regulator.
It all happened like this: Red "battery" light came on while driving. Checked charging voltage only 0.5V over battery voltage. Searched OOF & found alternator removal guides.
Note - removed airbox (as well as bagpipes) to give me elbow room to get my hand around back of alternator.
Got replacement regulator off the shelf from Vehicle Electrics in Birmingham (they are also on Ebay). Refitted alternator.
Note - Pushed pencil-sized telescopic magnetic retriever-thing through upper fixing holes & used it to guide the bolt through that was coming in from the back. With a bit of wiggling.
Started up - 15V charging. Hooray!
So big thanks to OOF for the guides.
K
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Alternator fix - a success story thanks to OOF
« Reply #1 on: 04 October 2011, 16:43:09 »
Great news! Result :y
« Reply #2 on: 04 October 2011, 18:41:57 »
K
If you think your notes make the job easier, PM Jimbob to update the guides :y
Abiton
« Reply #3 on: 04 October 2011, 18:46:24 »
15V is too high isn't it?  :-\
« Reply #4 on: 04 October 2011, 19:06:55 »
Hoping he read to nearest volt ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #5 on: 05 October 2011, 09:10:13 »
A little yes,should max out at 14.3 to 14.4 V
other rides
kevinminton
« Reply #6 on: 08 October 2011, 18:04:10 »
Found DMM & measured charging voltage at 14.26v. So that's OK then.
The "15v" reading was on a low-cost analogue meter that I keep in the mechanical toolbox.
K
« Reply #7 on: 08 October 2011, 18:22:43 »
Splendid news, well done K. 8) :y
