Author Topic: safe warning  (Read 1726 times)
kettle
  • milton keynes
    • 2.6 omega elite
safe warning
« on: 08 October 2011, 15:51:35 »
Have a strange fault , ihave a cid display works fine except when i fit the stereo which is a ncdc 2013 nav into car after about 20 secs display comes up red and says safe  both items were on car when i bought it showing safe on display any ideas how to fix .Have codes from vauxhall but have been told stereo doesent recognise code car is a y reg 2.6  elite.
Re: safe warning
« Reply #1 on: 08 October 2011, 15:55:01 »
a CID is paired to a head unit, it sounds like one of them has been swapped.
Sadly you cannot easily get a them re-programmed, if at-all. Codes from Vx will be useless, CID needs to be de-paired and set in delivery mode.
I'm not totally sure if yours can actually be de-paired  :-\
Re: safe warning
« Reply #2 on: 09 October 2011, 10:38:01 »
Does it say DISPLAY SAFE or RADIO SAFE, or randonly alternates between the 2?
If we can get it on a Tech2, depending which part is mismatched, there may be a solution.  Nearest OOF Tech2 is Brackley (yes, I know, thats off the grid ;D).
Do NOT ever, ever, ever use Evans Halshaw at Crownhill. Apart being wholly incompitent, they knowing charge for work they don't do.
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
Re: safe warning
« Reply #3 on: 12 October 2011, 22:56:30 »
Wow! I live round the corner from EH... Hopefully never need them....
