Author Topic: Bloody Golf!!  (Read 2573 times)
Bloody Golf!!
« on: 08 October 2011, 21:23:21 »
When I take the fuelcap off it hisses as a vacuum has built up.  It's got much worse today though.....
I'm going along quite nicely, when it splutters like it's out of fuel, but there's plenty.  So I stop, have a look and there's fuel leaking out the back!! I loosened off the fuel cap and fuel sprayed out!!  :o  There was a massive vacuum built up in the tank and I could hear things relaxing as the pressure was released... :(
It must be a blocked breather, but I don't know where to start!  There's a nozzle just in side the fuel pipe that can be wiggled!!
Any ideas??  :-\ ::)
millwall
  • se london
  • no muff too tuff
    • accord type s
Re: Bloody Golf!!
« Reply #1 on: 08 October 2011, 21:34:13 »
has it got the right fuel cap on it
Re: Bloody Golf!!
« Reply #2 on: 08 October 2011, 21:55:23 »
I think so...  :-\  I tried it with the cap loose and it still peed petrol out!!  :(
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Bloody Golf!!
« Reply #3 on: 08 October 2011, 22:10:13 »
Any ideas??  :-\ ::)
If fuel sprayed out then its not a vacumn that you have  ???
other rides
Re: Bloody Golf!!
« Reply #4 on: 08 October 2011, 23:51:50 »
As you say, it's a blocked breather/vent. Not sure what age of Golf but normally attaches high up on the tank, sometimes near the pump/sender. May well be a corrugated plastic pipe ;)
millwall
  • se london
  • no muff too tuff
    • accord type s
Re: Bloody Golf!!
« Reply #5 on: 09 October 2011, 09:17:46 »
taken from a vw forum a bloke on there has same problem and this cured it
There is a "breather" tube which vents behind the plastic liner in the rear offside wheelarch. You need to remove the liner, easy job provided you have the "Torx" attachments for a screwdriver. Locate the tube and ensure it is not kinked, you can use a straightened out metal coater hanger to poke out any dirt. That should sort the matter out.
Re: Bloody Golf!!
« Reply #6 on: 09 October 2011, 11:20:23 »
Thanks Millwall!!  :y  I'll have a look at that!!  :y :y
millwall
  • se london
  • no muff too tuff
    • accord type s
Re: Bloody Golf!!
« Reply #7 on: 09 October 2011, 14:45:58 »
if no joy with that tigger i will ask a vw mechanic that lives up the road :y
Re: Bloody Golf!!
« Reply #8 on: 09 October 2011, 20:54:17 »
Thanks Millwall.  I found another thread on the ClubGTI forum where two pipes were connected incorrectly into the purge canister.... It's abit vague tho... :-\
The symptoms are exactly the same.  I let it tick over today with the fuel cap off and fuel started welling up the pipe till it was spilling out!!  :(
Re: Bloody Golf!!
« Reply #9 on: 13 October 2011, 19:36:29 »
Problem solved!!  :)  It was indeed 2 pipes wrongly connected at the carbon canister!! Switched them round and job done, Happy days!!  :y :y :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Bloody Golf!!
« Reply #10 on: 13 October 2011, 19:37:56 »
Great result well done  :y
Enjoy it now  :)
