Pages: 1 [2] 3  All   Go Down
Author Topic: i might be in trouble when the missus gets back.....  (Read 3440 times)
Re: i might be in trouble when the missus gets back.....
« Reply #15 on: 10 October 2011, 15:16:39 »
I was just wondering the same thing. ::) ;D............how many PM,s can you send per hour ? ::) :P :D
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #16 on: 10 October 2011, 16:48:18 »
I have decided to go Supersize on my SG system ::)
Been buying your 10w40 in those 205 litre barrels? ;D
Nope but you're close.  125l hlt and boiler  ::)
« Reply #17 on: 10 October 2011, 16:52:26 »
 :o
Best you get a bit of a thirst on, then.
How many Tesco kettle elements is that lot going to need? ;D
Gaffers
« Reply #18 on: 10 October 2011, 16:55:31 »
Erm 3 in the boiler... ::)
« Reply #19 on: 10 October 2011, 17:48:58 »
That ought to make the lights go dim. ;D
Gaffers
« Reply #20 on: 10 October 2011, 21:21:28 »
 ;D ;D
Well I just picked it up.  I cheated and bought someone else's setup they were getting rid of.  He threw in the pump too.  Saturday is brew day !!
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #21 on: 10 October 2011, 21:26:30 »
When I was making home brew my ex used to say that the place stunk like a brewery, and like a good husband I agreed with her opinion ::) ;)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #22 on: 10 October 2011, 23:30:53 »
bloomin heck,  & heres me with a mere 25ltr. :)
« Reply #23 on: 11 October 2011, 09:45:10 »
;D ;D
I hope you've got a decent ring main in your garage. ;D
Gaffers
« Reply #24 on: 11 October 2011, 15:01:20 »
2 plug points and a ext cable into the house should do it  ;D
« Reply #25 on: 11 October 2011, 15:16:46 »
Multi-plug adapter and a bolt for a fuse? It'll be fiiiine.. ;)
Gaffers
« Reply #26 on: 11 October 2011, 16:05:11 »
Joking aside what's the highest I can out through a single and adaptor? :-\
« Reply #27 on: 11 October 2011, 16:32:20 »
Socket outlets are normally on a ring main rated at 32 Amps so that is the maximum you can pull through a ring main, with the load distributed around the ring. I believe a double 13A socket is specified to safely give you up to 20A with neither socket loaded to over 13A. Probably best that it is on the ring and not spurred from it if you're going to do that.
What is the rating of your elements?
I'm guessing they are either 3kw elements in which case they will take as near as damn it a full 13A, or around 2.2kW which is pretty much 10A.
So, a pair of 2.2kW elements should be safe on a double socket outlet, a pair of 3kW elements less so, although you might get away with it. The third element I would try to run from another ring main, if available, or from another socket on that ring main, well separated from the first one, so that the load is spread.
Beware that garage circuits, etc. are often fed from a spur rated at 16A.
Also beware that extension leads are often not rated for the full 13A, and any that are will need to be fully unwound.
That's the official line. Unofficially.. I'd try to find out how the sockets are wired so you don't overload anything, check that no socket outlets or any of the wiring you can get access to is getting worryingly warm and play it by ear..
I'm guessing you won't need all 3 elements flat out for a 90 minute boil, or whatever. You can probably drop it back to 1 or 2 elements once it's boiling and save leccy and minimise evaporation in the process.
I'd be happy to cast an eye over the installation and give you my thoughts if you like?
Gaffers
« Reply #28 on: 11 October 2011, 17:48:37 »
They are 2.2kw elements and the chap was saying that he only used 2 of the 3 elements to get a rolling boil and then one to maintain.  I'll check on the garage feed, as there is the freezer in there already I may have to look at the laydown or just switch off the freezer for an hour at a time.
More. Than happy for you to POP round and have a look if you wish, its a pretty impressive setup.  The mash tun looks fantastic, all metal, although I may have to make a sparge arm for it.  He said he begets needed one he just recycled the first runnings into the tun on the mash and the sparges (note plural :P)
« Reply #29 on: 11 October 2011, 19:06:36 »
Are you still speaking English?  ;) ;D ;D
Pages: 1 [2] 3  All   Go Up
