Author Topic: tech 2 needed  (Read 2713 times)
JIFFY
  • SOUTH WALES
  • "If it aint broke dont fix it"
    • 2001 2.2 cdx
tech 2 needed
« on: 14 October 2011, 01:16:05 »
hi guys,
anywhone out there with a tech 2 live near me? ime very close to cardiff wales airport,south wales,
need to reset an abs light after fitting an abs ecu,my local garage seems not to be able to get into my abs ecu to reset or configure it, any suggestions?
have booked the local vauxhall stealers for a weeks time just incase i need to go to them,
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Re: tech 2 needed
« Reply #1 on: 14 October 2011, 01:37:32 »
Have a look here:
http://theboy.omegaowners.com/tech2/prices.shtml
Looks as if TheBoy and Kevin Wood are nearest but both 150 miles or so.  Shame the Newent meet is over.
I feel like a military academy. Bits of me keep passing out.
mindaz
  • IRL , UK
Re: tech 2 needed
« Reply #2 on: 14 October 2011, 07:08:22 »
I think the only solution is to buy on ebey  ;)
Vauxhall/0pel 0mega 2.5 , 2002 , CD
Re: tech 2 needed
« Reply #3 on: 14 October 2011, 09:29:07 »
You'll be talking  a 4 figure sum for a proper Tech 2, though, which is what you need if the ABS ECU needs configuring.
Is the speedo working? It's not uncommon for ABS ECUs to fail completely whereby they give no speedo output and also refuse to talk via the diagnostic interface - as I guess you've found if you've swapped one. :(
They can be refurbed for reasonable money.
JIFFY
  • SOUTH WALES
    • 2001 2.2 cdx
Re: tech 2 needed
« Reply #4 on: 14 October 2011, 19:23:33 »
update for you all,as an afterthought went to a differant local garage today,he said we will at least give it a go for you,if we cant get into the ecu to read it,no charge,
left it with him for an hour,on return job done light out speedo workin all good,when enquiring what the problem was,
he said reader was showing no power to the unit,
yes you guessed it,   FUSE BLOWN,
but he did say he had never seen an abs fuse blown before and the old unit might of been knackered hence fuse blowing,
gave him £45.00 and left very happy,
just the m.o.t on tuesday now and i have a nice facelift for about £600.00,
thanks to twiglet for the new ecu,
happy days
sandune
  • Essex Southend
    • 2.6 Omega Auto
Re: tech 2 needed
« Reply #5 on: 14 October 2011, 19:56:56 »
Good news :y Fuses get's you every time :-[ ;D ;D
98CadillacCateraSport
  • Herndon, Virginia USA
    • 98 Cadillac Catera Sport
Re: tech 2 needed
« Reply #6 on: 15 October 2011, 20:20:32 »
The easiest solution is usually the most commonly overlooked
