Author Topic: Drivers heated seat not working?  (Read 6903 times)
Blackie_No1
  • Ballyclare N.Ireland
    • Omega Elite 2.5
« on: 15 October 2011, 21:54:45 »
. . . . . on my f/l omega elite, the memory and the adjusters work, just the heating element doesn't seem to come on.  What's the most likely causes?
2000 Omega Elite 2.5 V6
Re: Drivers heated seat not working?
« Reply #1 on: 15 October 2011, 22:07:20 »
Most likely is the element is toast :(
Blackie_No1
    • Omega Elite 2.5
« Reply #2 on: 16 October 2011, 07:14:53 »
Fudge!  :(
« Reply #3 on: 16 October 2011, 09:02:37 »
when leather elements go, there is normally some evidence that can be seen.
the element does seem to be the weakest point thougb
Blackie_No1
    • Omega Elite 2.5
« Reply #4 on: 16 October 2011, 15:45:42 »
What sort of evidence should I be looking for?  Leather seats in my car btw.....
« Reply #5 on: 16 October 2011, 17:35:56 »
Usually shows as a 'melted plastic' area, about size of 5p, or a singed line, normally around 1" long.
They can be repaired, but the repair process is best described as "challenging".
« Reply #6 on: 16 October 2011, 18:12:16 »
Or a blister on your arse. :y :D ;D
gareth.
  • Endor forest, South Wales
    • 2.5 v6 cdx leather
« Reply #7 on: 16 October 2011, 21:42:09 »
Funny you should say that!
My heated seat has been unbearably hot, now it doesn't work at all :(
If it's not broken, don't fix it.
Blackie_No1
    • Omega Elite 2.5
« Reply #8 on: 17 October 2011, 10:56:37 »
On the seat "skin" as it were?
« Reply #9 on: 17 October 2011, 11:13:30 »
Yup
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 17 October 2011, 12:03:22 »
These have always proved popular amongst the Oofers out there
http://www.dndservices.co.uk/am-haw.html
Radio & Decoding Technician
« Reply #11 on: 17 October 2011, 18:40:26 »
Have you had many takers from Leather seat Omega owners?  Not sure how well they would work on leather due to the thickness between where the pad would go, and the leather itself (padding is all stitched in)...
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 17 October 2011, 19:16:05 »
Sold many of these to people with leather seats -  :y
If you have the old ones stitched into the leather, its important to remove them first, as you wouldn`t want a good heat pad underneath the thickness of a dead one.
But they are certainly toastie enough to warm up even the thickest if hides.
And for the record, these are actually the WAECO ones that everybody bangs on about, I have just sourced them through one of their subsidieries and they are boxed and badged accordingly - hence the cheaper price !!   ::)
« Reply #13 on: 18 October 2011, 19:24:13 »
Elite heated LEATHER seat elements are part of the material. Imagine the Leather layed flat inside up, then the copper "wire" element laid directly on top in the desired pattern, then the seat foam and padding layered and glued directly on top of that again. There is no pad to remove, the element is effectively stitched and glued in as one.
 To remove the original wire the padding would have to be cut down to the element and the individual strand of wire chased out by hand. Likely leaving evidence of it from the surface in an electric blanket s shape covering the seat cover.
When repairing mine we(TB and I, you know what i'm like with sparks) noted
1 that the heated element is directly under the leather, so when it fails due to britlness and hence brekage in the individual strands of wire over time, the resistance is higher at that point, often over heating enough to mark the leather externally, and litterally scorch the internal padding black as if burnt by fire... And
2 that if fitting an aftermarket pad under leather, that removal of the old wire simply isnt practical and fitting a pad under Elite leather is very likely to give differant performamce as its simply not possible to fit a new pad at the samed depth/ditance from your arse as the original, as the padding is one with leather on the oe seat cover. So will take longer to heat up the occupiers arse or need higher temp or voltage(?) to give the same heat effect as the original with the ability to turn the heat down again once the desired heat level is reached.
Imo, if repairing heated elite leather seats, cut out and repair/solder/join the heated elememt itself where the scorching is, and do so knowing the whole process may very well need to be repeated if the element brakes again elsewhere. Sorry, but having seen how its made, i cant see hiw fitting a complete pad will work under an extra half inch of unremoveable seat padding given how long the oe current takes to warm up, esp when its so close the leather originally....Etc.
Blackie_No1
    • Omega Elite 2.5
« Reply #14 on: 19 October 2011, 16:57:10 »
good read above there Chrisgixer
there are no signs of the element being burnt out on the seat, leather looks to be all in good nick, no discolouration etc......
