Author Topic: Strange one this  (Read 1246 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Strange one this
« on: 16 October 2011, 12:21:01 »
3 ltr V6 with lpg conversion.
Had some nightmares over the last 3 years as some may remember so I have spent a lot of time lying on my back underneath the shed.
Replaced the backbox and all rubbers yesterday ( thanks to MaxV6 for sorting that one for us  :y :y ).
Over the last few years, I have noticed that one side ( off / drivers ) of the exhaust system never seams to be as hot as the other.   The same side always seams to seep water from the exhaust joints and eventually starts to blow meaning I end up lying on my back again with a spanner and a handfull of exhaust paste to gob it up   ::)
Before I fitted the backbox (twin pipe), I had a good look down it and noticed that you can see directly down one side and out the same side ( left / left ..... right / right ).
Started the engine to cure the paste and noticed that one side of the exhaust backbox exits is nice and warm, the other is cool and damp  :-\
I'm looseing a little water but that is down to a small leak on the lpg side that needs sorting.
The car has also started to hunt at idle.
Not enough to cause a problem ie- codes or stalling.
Never really been a problem before but now I know that there is a direct path ( left and right ) through the backbox, it bugging me  :(
Can anybody shine any light on this please
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Strange one this
« Reply #1 on: 16 October 2011, 12:39:05 »
Should also add that it starts with the first turn of the key but it does run hot when on lpg.
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #2 on: 01 December 2011, 00:22:12 »
just a thought.....   since no one else seems to have any input....   but might it suggest a leaky manifold gasket?? sucking cooler air in on one side????
(i know this threads been stagnant....  i just happened across it....  )
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #3 on: 01 December 2011, 08:50:31 »
Thanks Max   :)
The exhaust does seem to be blowing a little ( or someone has sneaked a v8 under the bonnet )  ;D
Mpg is definetly down a little  :(
The exhaust has been on and off alot over the last 6 months so i'll have a look round there over the weekend.   Daz blanked off the SAI bits last year so maybe I might have knocked something  :-\
Either way, its still hunting at idle on both gas and petrol so something ain't right  :(
Diff end plate has been removed, oil drained ( what little they was in there ) and nice fresh oil and additive put back in.
