Author Topic: Side trims  (Read 1610 times)
mantaray
  • Coventry
Side trims
« on: 17 October 2011, 20:55:31 »
Do the facelift side trims fit a mini facelift car ? and if so can you still get the clips as I know some will get brocken taking them off.
Thanks for any help.
2.6 CDX Auto Estate,
71 Opel Manta A Series 2.5 V6
Re: Side trims
« Reply #1 on: 17 October 2011, 21:01:31 »
Sill trims, or rubbing dooe trims?
Re: Side trims
« Reply #2 on: 17 October 2011, 21:02:51 »
Yes they fit.I believe there may be a guide for doing it. :-\
Not sure if the clips are available new from dealers,I would imagine threy would be if you needed them. ;)
Re: Side trims
« Reply #3 on: 17 October 2011, 21:03:09 »
They must be! They've been fitted to loads of earlier cars, so clips etc must be available ............ assuming they're not been glued on.  :y :y
Re: Side trims
« Reply #4 on: 17 October 2011, 21:05:01 »
I assumed dooe trims. :-\  sill covers are usually called..er..sill covers. :-\ :D
Although the sill covers would be the thing more likely to give trouble with clips. :y
Re: Side trims
« Reply #5 on: 17 October 2011, 21:05:41 »
Dooe = Door. :-[ ::)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Side trims
« Reply #6 on: 17 October 2011, 22:10:14 »
RIP Paul Lovejoy
