Author Topic: power steering pump failed  (Read 7064 times)
The Duck.
  • Enniskillen. Co Fermanagh.
« on: 21 October 2011, 12:57:28 »
can someone point me in the right direction on where i'd get a pump for a 98 30 MV6. Or if u have one please contact me. Im starting to look a little like popeye around the arms  ;D
Re: power steering pump failed
« Reply #1 on: 21 October 2011, 12:59:42 »
Send a PM to Albs. He may have one
The Duck.
« Reply #2 on: 21 October 2011, 13:00:42 »
cheers
« Reply #3 on: 21 October 2011, 13:02:50 »
Needs to be from a 2.5 or 3.0ltr. If you can source one from a 2.6/3.2 you`ll need the pipework to the pump as well.
The Duck.
« Reply #4 on: 21 October 2011, 13:08:55 »
I was told by a breaker the 2.6/3.2 are different. so its just the pipework  :y
« Reply #5 on: 21 October 2011, 13:25:08 »
« Reply #6 on: 21 October 2011, 19:22:06 »
Been contacted by duck and I do have a goow one for him.I was just about to check for certain that it will be the correct one.I remembered there was some change in spec at some point. Smartarse RobG has (as usual)  already provided the answer. :y
« Reply #7 on: 21 October 2011, 19:22:37 »
Good - not goow. ::) :-[ :D
« Reply #8 on: 21 October 2011, 19:26:45 »
One last  thing Duck - have you checked the other possible causes such as a blown fuse, before replacing the pump ? ;)
« Reply #9 on: 21 October 2011, 19:33:16 »
Naff off :P
« Reply #10 on: 21 October 2011, 19:34:49 »
 :-* ;D :-* :D
« Reply #11 on: 21 October 2011, 19:36:35 »
And???????????? :P
« Reply #12 on: 21 October 2011, 19:40:51 »
Lack of luid/old manky fluid/fluid leak/a.n. other electrical fault between power supply and speed sensitive assistance. ;) :P ;D :P
« Reply #13 on: 21 October 2011, 19:41:27 »
And ::) ::)
« Reply #14 on: 21 October 2011, 19:46:37 »
Rather generalised comment. Why don`t you just sit on the fence :D :D
